Home > Maintenance & Modifications > Passenger Airbag - On board Computer says disabled?
Moonpig1971
Hopefully someone can help with this?
The switch on the left hand side of the dashboard is set to indicate that the passenger airbag is on.
However, when i start a journey the on-board computer is informing me that the passenger airbag is disabled.
Has anybody had this before or know how to fix it?
TIA
Matt Newbie to the world of the RRS... Purchased 1st one in April 2017, currently blown away by the ride & quality. Lets hope that feeling long continues.
Post #525559 Mon May 08 2017 9:24am
If you are referring to the message that flashes up up by the temp control switch mine has always done that from day one. I just assumed it was a system check prior to starting car. No faults shown in memory at all.
Post #525564 Mon May 08 2017 10:37am
Moonpig1971
Hi Col.
Yes exactly that.
So i presume all ok then?
Thanks for the reply
Post #525566 Mon May 08 2017 10:47am
Eaters
From the handbook:
In order to fit a child restraint to the front passenger seat, use the starter key to turn the airbag disabling switch to the OFF position.
Check that when the vehicle has been switched on (position ll), the operational status lamp on the instrument panel is illuminated indicating that the passenger airbag is NOT operational.
By implication, the operatioanal status lamp remains illuminated all the while the airbag is switched off. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #525567 Mon May 08 2017 10:49am
Moonpig1971
Thanks Eaters, hopefully i'm now all good
Cheers Newbie to the world of the RRS... Purchased 1st one in April 2017, currently blown away by the ride & quality. Lets hope that feeling long continues.
Post #525579 Mon May 08 2017 12:36pm
