Home > Technical > Spark Plugs & TH leads |
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 |
Hi all, I am after new spark plugs and HT leads for my 2006 RRS Supercharged
Tue Mar 21 2017 9:24pm |
thanks Andy I am a head don't know why I typed HT leads
Tue Mar 21 2017 9:41pm |
2006 Supercharged Engine Ignition
Wed Mar 22 2017 3:56am |
90% certain the slight miss fire (more of an engine stumble, can't be heard but you feel the shudder through the steering wheel etc?) will be the injectors need cleaning.
Wed Mar 22 2017 10:17am |
I to have this stumble is a tin of injector cleaner enough or does it take more as it's only on tick over everything else is ok |
Wed Mar 22 2017 11:39am |
It's worth trying a can or two of BG44 to see if that helps, getting the injectors out is quite a big job. |
Wed Mar 22 2017 12:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4804 |
I've been told to increase the plug gap on my Jag from 1.0 to 1.3mm (probably go for somewhere in between) to make it idle better. |
Wed Mar 22 2017 1:08pm |
Have you changed the plug gaps on your Jag ?
Wed Mar 22 2017 1:31pm |
Not yet. Hopefully I'm gonna try and measure the gap at the weekend, but won't drive for a while |
Wed Mar 22 2017 6:29pm |
From what I can make out, this only applies to very early jags, (long before the RRS) and Iridium plugs seam to get set to 1.0mm |
Sun Mar 26 2017 2:29pm |
I had a look after you mentioned it and as you say the default plug gap on the 4.2SC is between 0.9 and 1.0 mm.
Tue Mar 28 2017 7:53pm |
I have ordered a can of BG44 let se if t makes a differents! 2006 RR Sport Supercharged Love this car
Sun May 07 2017 4:58pm |
my jag Iridium's were at 0.9mm so moved them to 1.1mm |
Sun May 07 2017 5:35pm |
any change? 2006 RR Sport Supercharged Love this car
Sun May 07 2017 5:36pm |
