Home > In Car Electronics > Bluetooth connection |
Probably microphone wire is cracked, straight forward to replace if problem comes back. Bodsys Brake Bible
Sun Apr 09 2017 12:24pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Thank's Bodsy
Sun Apr 09 2017 12:26pm |
The microphone is in the light unit, behind where you see those small vents above. The crack int eh wiring is usually before the connector. You can wire in a new wire between the radio and the microphone. Just need to feed it through and up the A pillar and along the headlining. Bodsys Brake Bible
Sun Apr 09 2017 12:32pm |
Much appreciated
Sun Apr 09 2017 12:35pm |
