Home > In Car Electronics > How to avoid a flat battery |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1536 |
Hmmm. Just a few words to help any others as stupid as me. Wanted to pump up the tyres on my bike and being lazy, decided to use the electric pump I carry in the RRS. Used the power socket in the boot and it worked just fine once I had turned on the ignition - just to the first position you understand so that there was power in the rear socket.
Sat Mar 25 2017 7:48pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Ok to connect the positive direct but negative should be clamped to an earth and not the negative battery post....that's my understanding.
Sat Mar 25 2017 11:20pm |
I'm sure I read that somewhere but by o-level physics says " what's the difference?" So I just connected to the terminals
Sat Mar 25 2017 11:44pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4893 |
People just worry about things sparking near battery vapors and causing an explosion
Sat Mar 25 2017 11:47pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1062 |
Yep no different to any other car - there is nothing mystical about the RRS if you leave the ignition on in any position and charging the battery is exactly the same as any other car. It is easier to put the negative lead of the charger on the body post rather than try to get at the -ive on the battery but all else is the same.
Sun Mar 26 2017 2:36am |
Riverblanche - on a slight aside - I have two tow sockets fitted (and presumably wired) but have never towed. I believe one is for lighting and the other is for power to say a caravan. Which I would use to trickle charge? And is there a note somewhere about wiring up a plug for this? Robin
Sun Mar 26 2017 8:20am |
If you go in the forum shop you can purchase a plug for use with tow electrics and a trickle charge 👍 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Mar 26 2017 8:33am |
Cheers Buckster Robin
Sun Mar 26 2017 8:41am |
Not sure what charger you have but i use a CTEK via a 13pin on the tow electrics 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Mar 26 2017 8:46am |
White plug for power.
Sun Mar 26 2017 10:59am |
Mon Mar 27 2017 5:55pm |
Thanks for the thoughts and advice all.
Mon Mar 27 2017 11:09pm |
