![]() | Home > Technical > Dreaded suspension fault |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It could be a few things, most likely is a height sensor isn't right (check the 4x4 info and see if one wheel is showing as being high/low), another posability is that the steering angle sensor is out of alignment.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
4 x 4 screen shows all sensors ok and none of them flashing red and diagnostics was plugged in like I said in the above post and no faults stored |
Sorry, I hadn't read your post properly and missed that no codes are stored. |
just checked the 4x4 screen and all the height are displaying the same in all 3 height settings.
Is the car sat on level ground and is the car itself sat level (measure from tyre to wheel arch) ?
The car is on level ground and all the tyre to wheel arch measurements measure the same height whichever height setting it is on.
your local indy will be able to sort it for you (if it is the problem) |
