Home > Maintenance & Modifications > Help - rear rattle and feels like flat tyre |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Have a drive around and then stop and feel the rear wheels to see if either are warm to the touch. If one wheel is warm and the other cold it could be a sticking rear brake caliper or handbrake release mechanism. I'm in the shed, I'll be back in the real world in a minute. |
Sun Mar 05 2017 5:33pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I assume your choice of the word "rattle"was intentional. If it were more of a grinding noise (perhaps like the flat tyre you mentioned) I'd check the wheel bearing as well Robin
Sun Mar 05 2017 7:17pm |
061music Member Since: 29 May 2015 Location: Manchester Posts: 38 |
Hi
Sun Mar 05 2017 7:24pm |
Thanks, will try that |
Mine is currently in the dealers after there was a vibration like a rear tyre was out of balance or had a flat spot. Turns out it is both a seizing calliper and on the opposite side a sticking handbrake release mechanism. One wheel was warm/hot (seizing calliper side) and the other cold.
Sun Mar 05 2017 9:39pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
EPB shoes
Sun Mar 05 2017 10:56pm |
v8ranger Member Since: 15 Mar 2013 Location: Essex Posts: 11 |
I had the same symtoms,rattling on OSR wheel, which then led to the wheel locking up. It turned out to be the EPB shoe,had delaminated from the shoe carrier and eventually jammed the disc solid. Luckly this happened on way to get it sorted and not on main road.
Mon Mar 06 2017 3:22pm |
oh dear, sounds like an unfortunate set of events. I've booked mine in to be looked at on Wednesday so fingers crossed its something simple.
Mon Mar 06 2017 3:56pm |
Heard from the garage today that the rear propshaft had collapsed which is what was causing the rattle and clunking. new part ordered from land rover and just over an hour to fit |
Thu Mar 09 2017 7:18pm |
