Home > Technical > 2.7 with ACE alternator removal |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 |
Tue Feb 14 2017 8:39pm |
Once it has all three bolts out you can shove it down and get to the bottom two 13mm alternator bolts, they will come out with the pump pushed down.
Tue Feb 14 2017 8:42pm |
Et voila
Tue Feb 14 2017 8:48pm |
Thanks a lot, a very handy reference for those that may need it. (Shame about the idler ) John
Tue Feb 14 2017 11:32pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Fantastic help, I'm going through the exact same process and could only find how too without ACE, I'm still at the fan removal stage, it's being a bit of a pig (so tight) I'm going to order "special tools" and hopefully will do the trick, great guide, Hope you get Idler sorted ok. |
Wed Feb 15 2017 5:12am |
My fan was very tight to and doing it on your own needs three hands . I got a building wall strap the ones used for wall plates , drilled out the end hole bigger to take one of the water pump 10mm bolts , took one out and screwed the strap on. I used a longer bolt . Then turned the fan so the strap jammed under the pully and sat a block of wood across the engine for it to push against. Once it was in place you can get both hands on a big spanner on the fan |
Wed Feb 15 2017 6:46am |
Sounds like a good plan to me, please forgive my ignorance but do you mean one of these
Wed Feb 15 2017 7:56am |
Yes that's it , the hole needs opening up to and I did grind the side away a bit to allow the fan flats to turn. Bear in mind anything will do |
Wed Feb 15 2017 9:12pm |
Apologies for photos as it's dark, but kind of like this. My straps were to short hence the join
Wed Feb 15 2017 9:19pm |
Fantastic, THANKYOU kindly, will get bk on it Friday weather permitting. |
Wed Feb 15 2017 9:27pm |
I have to fix my idler bracket first but then I will start to put back together so will let you know any issues as I go mate |
Wed Feb 15 2017 9:49pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
I ordered a set of these
Thu Feb 16 2017 11:08am |
Hi mate
Thu Feb 16 2017 12:42pm |
I have been looking at the tools on the link provided but can't understand how they will undo the fan as they look quite hard to get any leverage on them, if holding pulley with pry bar and large adjustable on fan nut being shocked with a large rubber mallet didn't work. (But that's why I'm probably not a mechanic) keep us posted how you get on with the recommended tools and how tight your fan was. 👍 |
Thu Feb 16 2017 1:46pm |
