Home > In Car Electronics > Where's the Mute button?
Bill Portland
Driving along, listening to the news on radio 4 and I realised that, unlike my previous car, there's no mute button to quickly cut off traffic info or sat nav directions.
Is that right or am I missing something?
Post #517544 Sun Feb 12 2017 7:39pm
Not one.
Press the volume in to turn off radio.
There is a Nav mute on the touch screen but that's no use in a hurry Laughing
Post #517545 Sun Feb 12 2017 7:49pm
Paddi
If you press the 'C' button at the bottom right of the headunit it shuts off the Traffic Info that is coming over the FM from a station other than the one you are listening to but only until the next broadcast.
Found that out by accident one day but it is quite handy since turning off the Traffic Info completely of course means you will miss the announcement that the M25 is closed at Junction 27 again.
Going a bit off topic now but WHY is it always Junction 27? 2008 MY Java Black TDV8 HSE
Post #517554 Sun Feb 12 2017 8:46pm
Bill Portland
'C' button? I don't seem to have one of those either.
Post #517560 Sun Feb 12 2017 9:32pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Not sure if it's the same thing but pressing the Audio button cuts off the current traffic announcement and reverts back to whatever Audio you are listening to.
Post #517562 Sun Feb 12 2017 9:50pm
Bill Portland
I'll try that on the morning commute. Cheers!
Post #517563 Sun Feb 12 2017 9:55pm
Eaters
On mine the info button (bottom left of head unit) turns traffic announcements off if you push it once whilst that info is being broadcast but it will still allow the subsequent traffic broadcast to come through. Push it twice if you want to turn traffic announcements off whilst they are being broadcast (or once if no traffic info is being broadcast).
For navigation you can mute the voice whilst still retaining visual support. It's in the nav settings. It will then show a loudspeaker with a line through it bottom right of the nav screen. If you touch that symbol at any time it will tell you the next route instruction whilst still remaining mute for all others.
Hope this helps although they probably changed everything between 2008 and yours! Confused Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #517569 Sun Feb 12 2017 11:13pm
Bill Portland
Yep, that works for the traffic announcements (although it does switch the screen to the audio/video mode, obviously.
Any way to cut off the sat nav direction announcements other than permanently?
Post #517591 Mon Feb 13 2017 10:51am
Bill Portland
You were right, everything has changed since 2008 and mine! I don't get the "loudspeaker with a line through it bottom right of the nav screen" but I do get a "repeat last announcement button"
Post #517592 Mon Feb 13 2017 10:53am
