Home > Faults & Fixes > Headlight Condensation - Help Please! |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Not sure if you can remove the whole unit on the 2005 V6 (like you can on my V but if you could leave it on a radiator in your house overnight to dry out then see if the problem reoccurs when you refit it, you'd at least know if it was a one off problem or something more serious
Thu Feb 09 2017 11:45pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The units have a number of breather pipes on the rear so it should clear with time anyway. On the odd occasion mine have had some condensation, just driving with the lights on for a while usually clears it. The heat dries them out via the breather pipes. Last time mine did it was after I changed the bulbs on a damp day. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 09 2017 11:48pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
same thing happened t me, on my drivers side, the units take about 2 mins to remove, take in side, remove the bulbs and leave to dry somewhere warm, can also spray some glass cleaner inside to stop water marks forming on the inside of the lens, I've got some new sealant bonding strip, (a bit like bitumen strip) so when the weather warms up, I'm going to remove the lens and old sealant and replace it. |
Fri Feb 10 2017 9:04am |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Ok, here I am confirming how rough I can be....
Fri Feb 10 2017 12:45pm |
Sgthomer99 Member Since: 17 Nov 2016 Location: Devon Posts: 12 |
Thanks for all your advice guys, seen some videos on You Tube using hairdryers to dry them out! |
Fri Feb 10 2017 8:10pm |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Both of mine have condensation in them going up about 2 inches from the bottom which I assume it caused by the dealer pressure washing the engine bay before coating in bull*hit shine.
Mon Feb 13 2017 8:46am |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 |
Its down to the headlights (and LED Tail lights) being more efficient and not burning so hot, condensation tends not to vapourise. (Cold exterior, slightly warmer interior effect)
Mon Mar 20 2017 2:12pm |
