Home > Maintenance & Modifications > Lumpy Rough TDV8 Engine - Newbie needs help! |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Get the codes read which might show where the issue is.
Sun Jan 15 2017 4:18pm |
Agree that reading the fault codes is the logical starting point.
Mon Jan 16 2017 3:15pm |
cue_ball80 Member Since: 15 Jan 2017 Location: Fareham Posts: 9 |
Well now that is impressive Paddi!
Mon Jan 16 2017 5:58pm |
I'm not counting any chickens until you report back after the sensor is changed. Regarding the live EGR values I was a bit surprised to see them jumping around so much on my own vehicle too but they are different from those on the TDV6 and I think the constantly changing values might be normal. Unfortunately there seem to be no 'control' traces published to use as a comparison. 2008 MY Java Black TDV8 HSE
Tue Jan 17 2017 12:12am |
Ok - sit rep! Oil temp sensor replaced... No change at all!
Thu Jan 19 2017 9:55pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Check the injector live values |
Thu Jan 19 2017 10:16pm |
Fault codes read on Monday (apart from the odd electrical gremlin signal fails to speed control module and terrain control module which all work 99.9% of the time) were...
Fri Jan 20 2017 2:18pm |
Mark is a highly rated chap in the area
Fri Jan 20 2017 3:01pm |
I agree - Mark @ West 4x4 is fantastic! He's been really helpful through my fault finding.
Fri Jan 20 2017 3:21pm |
Interesting thread. Something seems very odd though. If the EGRs are faulty, would the engine run normally when cold or up to full temperature? Still sounds like a problem with incorrect fuelling possibly due to the engine ECU receiving false information about temperature during the warm-up phase.
Fri Jan 20 2017 5:14pm |
Well took a trip to Avon Tuning today (2hrs each way but they have done over 50 EGR deletes on TDV8's in their time and produce their own EGR blanking plates from laser cut sheets).
Wed Jan 25 2017 9:49pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Looks like you've seen the last of your issues, great result. If you don't mind, what was the cost for the EGR delete? |
Wed Jan 25 2017 11:42pm |
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 |
Glad you got it all sorted cue_ball80, I live in Fareham too I may see you around! 2006 RR Sport Supercharged Love this car
Thu Jan 26 2017 7:31am |
Cost £300 to blank off and alter software - cheapest EGR replacement (changing both together using genuine parts) was £815inc VAT. I see that as a £515 saving and never having any EGR related problems ever again, plus better fuel consumption so can't be a bad thing!
Thu Jan 26 2017 10:04am |
