Home > Technical > Remap Options |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
Maybe you should have purchased a BMW or Astra
Wed Jan 18 2017 1:58pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4349 |
My Discovery has a Stage 2 map by Alive
Wed Jan 18 2017 2:15pm |
Most of the time i chug around and would prefer MPG gains over HP for everyday use, but every once in awhile I'll see a nice stretch of road or simply want to got WOT to scare the wife. |
Wed Jan 18 2017 2:20pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1144 |
a normal Stage 1 remap will give you better consumption if you don't drive it like a hooligan.
Wed Jan 18 2017 2:28pm |
Your MPG is directly related to the position of your right foot |
Wed Jan 18 2017 3:08pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Disco_Mikey is 100% correct
Wed Jan 18 2017 3:15pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
DM is totally correct. A decent map will give economy if driven gently and performance if driven hard.
Wed Jan 18 2017 3:20pm |
I appreciate that a re-map will most likely give an increase in mpg when driven sedately, however the throttle response is quite sharp. If you have a more balanced/stock map you don't have to worry about blipping the throttle while on rough/wet roads and nailing yourself to the back of your seat or spinning out.
Wed Jan 18 2017 3:56pm |
Just buy a SVR & you will have loads of power,,550 horses then have it mapped to 575
Wed Jan 18 2017 4:28pm |
Would if I could.. |
Wed Jan 18 2017 4:33pm |
haha, relax dude, no one's saying you're a chav/boy racer, etc.
Wed Jan 18 2017 4:49pm |
double post,,can someone delete this pls Andy.
Wed Jan 18 2017 5:00pm |
I think you might be overreacting a little, I assumed the comment about buying a BMW was for the eco mode which adjusts map and throttle angle, not about calling you a chav! Everyone else was just explaining why you generally dont need two maps, and thus theyre not normally offered (Plus offering it on a stock ecu generally involves flashing custom code into the ECU).
Wed Jan 18 2017 6:00pm |
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 |
quite a fair question to be fair:
Wed Jan 18 2017 6:22pm |
