Home > Maintenance & Modifications > Replacing ACE pump |
I've done it on the 4.2 SC and it's not too bad. You need to remove the wheel liner and a small part of the under tray. Not sure if the pump is in the same location on the TDV8 though. |
Fri Dec 16 2016 2:55pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8875 |
According to the book of lies, you need to remove the cooling fan and the generator (alternator) to change the dynamic response pump.
Fri Dec 16 2016 4:39pm |
