Home > Technical > pre heater not working with command from Britpart |
The pump is underneath the car, just in front of the gearbox support crossmember. It's about 7cm long and about 4cm wide. Bodsys Brake Bible
Sat Nov 26 2016 3:34pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4817 |
the pumps not that far from the fuel filter |
Sat Nov 26 2016 4:41pm |
Goose Member Since: 07 Mar 2016 Location: Leuven Posts: 5 |
Okey I will check this on monday, anyone has a id how this pomp is activated ! By relay with a fuse between and yes were to find ore is the webasto giving a inpuls on this pomp! Any one has a diagram from this system? |
Sat Nov 26 2016 8:20pm |
Okey Feedback about this pump I found the pump and started ths webasto the pump is not working dont here ore feel this pump working, ive checked this pump but its works with impuls so dont work on 12v, if I started the webasto system ive checked were the fuel going in the webast no fuel. Ive checked with a v meter on the pump conection and messures 9V,
Wed Nov 30 2016 9:30pm |
When going through the process of starting, the FBH will first fire up the glowplug and the combustion fan in the FBH. The fuel pump does not come on until the glow plug has reached temperature.
Wed Nov 30 2016 10:49pm |
Just to give you feedback today I diagnostic the problem with a computer and find out that the themperature sensor has to be changed , he will give the signal to go in action to the fuel pomp, so ordered it today and wil be delivered tomorow ore monday. |
Thu Dec 01 2016 2:17pm |
Update I just changed the temperture sensor and did a reset disconect battery and held the two poles together for ten seconds after reconnecd and starting the system webasto it worked for only 1 min, I must go to the garage to connect the computer and he must say to the car you have a new sensor and than it will hopefully works. I will give feedback later. |
Mon Dec 05 2016 7:51pm |
