Home > General > another door latch |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
These seem to be a weak link in design. I have just replaced my second lock on a 2005, I hope you don't have the same issue I had and the new lock failed after 2 weeks with the lock jammed shut faced with lock destruction to gain entry .
Sat Oct 29 2016 9:21am |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
i think i paid 190 last time supplied and fitted, this is my second one |
Sat Oct 29 2016 10:20am |
well new door latch fitted £225 later, so on to the next problem oh the joys |
Wed Nov 02 2016 6:19pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
You know that You can "refurbish" the latches?
Fri Nov 04 2016 12:34am |
OLIVER Member Since: 06 Nov 2014 Location: 50110 NORMANDIE Posts: 5 |
Thank you
Fri Nov 04 2016 6:46am |
Thank you
Fri Nov 04 2016 6:50am |
Personally I would stay well away from refurb. If your skills are right and you know what your doing that's great so go for it. What happened to me the other week after fitting a new lock is the lock failed after 2 weeks Jammed the door lock on, you cannot open the door from inside or out. You are then faced with lock destruction and brute force to destroy the mechanism to gain access. So for me personally to balance the risk of getting it wrong and a new lock is no brainer. |
Fri Nov 04 2016 8:36am |
yeah i agree not worth the hassle to save £100 |
Fri Nov 04 2016 7:38pm |
