Home > In Car Electronics > Blown.........and missing fuse ? |
Paul_selby Member Since: 05 Sep 2016 Location: North Yorkshire Posts: 33 |
Evening all . Just been replacing all the 501 type bulbs for led replacements , got to the last ones (the rear map reading ones) and I have let the contacts touching, blowing a fuse . I don't have an owners manual to hand , and have found the interior fuse box but can't make out which fuse would be for the interior lights . Whilst I was looking I noticed there is a fuse missing from position 52...............any help appreciated |
Thu Sep 15 2016 10:03pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
It's at the top.
Thu Sep 15 2016 10:27pm |
Thanks Andy , I'll have a look 1st thing tomorrow |
Thu Sep 15 2016 10:47pm |
Fuse No.1 Top left
Fri Sep 16 2016 12:06pm |
Spot on Andy thanks . Just a note to anyone changing the rear map lights from bulb to led........if the LED have a metal housing they will blow the fuse. There are 2 stabiliser bars that help hold the standard 501 bulb in place , but these (now I can see in the daylight ) are connected to the live and earth connection, so either need to be bent slightly open or snipped off . Hope this helps some to not make the same mistake I did ! Thanks for the info Andy |
Fri Sep 16 2016 2:35pm |
Fri Sep 16 2016 3:06pm |
