Home > General (L494) > Tracker (Thatcham) |
Once your original subscription has run out (you can select 1/2/3/5 years at time of purchase) you just renew at whatever the current rate is for subscription then and purchase again for how many years you want. If you know you are keeping car, there is good discounts for purchasing more years.
Mon Sep 05 2016 11:34pm |
Hi,The cat 5 is the best on the market at the minute,the one I chose also has uhf aswell as gps & GSM so it can be tracked in a container or underground car park.
Tue Sep 06 2016 6:42am |
gavwhite1972 Member Since: 23 Aug 2016 Location: Retford Posts: 33 |
hi how does this compare to the LR Trackstar? I just had a quote off LR Marshalls in Lincoln for £399 supply and fit, and another £399 for 3 years subscription (or £180 per year) So the LR one is cheaper with 3 years subs.... but any thoughts on how it compares?? |
Tue Sep 06 2016 10:48am |
If its the LR Trackstar then its cheaper off these guys but its not as good as the cat5.
Tue Sep 06 2016 11:21am |
I believe the LR Trackstar is a Cat 6 unit not Cat 5, you may realise this but didn't want you getting wrong possible unit.
Tue Sep 06 2016 7:32pm |
Thank you...
Mon Sep 12 2016 9:56pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
https://www.thatcham.org/files/pdf/Definit...gories.pdf
Mon Sep 12 2016 11:06pm |
