Home > General > TDV8 leaking coolant |
Did the new coolant bottle come with a new cap? A faulty cap can cause what you describe. The pressure test won't show it up because the cap is removed and the pressure tester takes it's place during the test. 2008 MY Java Black TDV8 HSE
Tue Aug 16 2016 3:49pm |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
Thermostat housing in the middle of the V at the front, quite common for leaks spiteful Range Rover Sport tdv8 |
Tue Aug 16 2016 11:26pm |
Brad83091 Member Since: 23 Jan 2013 Location: Limerick Posts: 17 |
No. The old one was reused |
Tue Aug 16 2016 11:49pm |
Cheers. Is there much dismantling to examine that |
Tue Aug 16 2016 11:50pm |
