Home > Maintenance & Modifications > Change my belts (Cam belt unsure what others?) @ 106,000
BenDE1
United Kingdom 2008 Range Rover Sport TDV6 S Stornoway Grey
Hi All,
As a new comer to the fourms and the mechinical world i am hoping to seek some advise from fellow RRS owners and someone with more experience than myself.
I recenetly purchased a 2008 / 58 plate RRS (S Model) with HSE upgrades however the millage is now at 106k.
The service history seems good and the car had a new turbo supplied and fitted by landrover at 90k however does not state anything about the cam belt or other belts.
As i previously owned a 2011 range rover last year i would like to seek advise on what belts i certianly should look to change, is the main priority just the cam belt or do other belts also need a change?
I ask this as there are some devious mechanics out there whom just see ££ signs when one attends a garage for further advise and suggest work that may or may not be required.
I have a certain budget to stick to so if anyone reading this can also recommend a mechanic in the derbyshire or leicestershire area i would certainly look to proceed as soon as possible to ensure the right belts and work is completed by a component person(s).
Look forward to any advise, much appreciated for reading this post.
-- Edited:
As there is no record in the service manual and its past 105k and the 7 year mark, How could i know if the cam belt has already been changed as i am unable to contact the previous owners Sad
Thanks
Ben[/i]
Post #502050 Wed Aug 03 2016 1:16am
The main belt to do is the front cam belt.
The rear fuel belt is usually done within the cost. (assess is a pain though)
The auxiliary belt may as well be changed at the same time as it has to come off anyway, and can't cost much more than £10
It's worth taking the plastic engine cover off and seeing if there is a label ontop of the cambelt cover to state it has been changed.
Post #502060 Wed Aug 03 2016 12:10pm
Disco_Mikey
You need to weigh up the cost of having the belt replaced, against the cost of a replacement engine or rebuild, and then make your decision Thumbs Up
Post #502066 Wed Aug 03 2016 1:05pm
belt replacement £400-500
replacement engine £2000-3000 ?
Post #502090 Wed Aug 03 2016 7:40pm
Disco_Mikey
And the rest. An engine weighs in at £2,500 (ish) before fitting, new belts, fluids etc...
Post #502108 Wed Aug 03 2016 9:54pm
BenDE1
I have been quoted abut £500 for the front and rear belts to be changed, Would you say this is about right?
I have also been quoted £180 for new front disks and pads.
I dont mind paying for work to be done as the last thing any of want is our cars going wrong, I have seen a company in derby that are land rover specialists and have quoted to prices above so hopefully there as good as they come accross to be.
Post #502163 Thu Aug 04 2016 3:44pm
Disco_Mikey
For info, I charge £400 for belts, and £200 for discs and pads Thumbs Up
Post #502167 Thu Aug 04 2016 4:28pm
BenDE1
Im in derby though? You in dundee?
I also need satnav update to 2015/2016
Very Happy
Post #502197 Thu Aug 04 2016 7:15pm
garrycol
Australia
When you coming to Canberra in Australia to do my belts - it is so expensive here.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #502215 Fri Aug 05 2016 3:56am
Disco_Mikey
Pay for my flights, and I'm there Whistle Laughing
Post #502216 Fri Aug 05 2016 6:48am
SRE
Spain
Now that may be worth thinking about. Bow down In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #502218 Fri Aug 05 2016 7:41am
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Disco_Mikey wrote:
For info, I charge �400 for belts, and �200 for discs and pads Thumbs Up
Hi disco-Mike.
I know it’s a different topic but what software updates can you have on my2010. New to rrs car.
Post #576303 Sun Mar 03 2019 9:03pm
