Home > General > swaying while driving on uneven road surface
marka
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Lux Java Black
Hi Can anyone help with this, I have just bought an 05 RRS,
it has 22" wheels on and it feels very unstable on uneven road surfaces, if you hit a pothole it seems to veer off in any direction, could this be a shock issue ?
any help would be appreciated before I spend any more money
thanks
Post #500230 Wed Jul 06 2016 9:49am
Tim in Scotland
Welcome to the forum Mark, I hope the following isn't too much bad news...........
2005 RRS was never designed to take wheels bigger than 19" and even then you needed a different steering rack unless you had a 2005 4.4V8, 4.2 S/C, or an HSE with the factory option of the Dynamic Pack that came as standard with 20" wheels and the uprated steering rack. Even then Land Rover dealers would void a warranty if you took your car in with wheels bigger than 20". I would suggest that the 22" wheels and tyres might have led to accelerated wear of the steering rack and you have a lot of play in it..... It wasn't a difficult job for dealerships to change a steering rack and with 2007MY all RRS's got the uprated rack as standard. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #500237 Wed Jul 06 2016 10:51am
marka
Hi Tim
Thanks so much for the prompt reply,
It is a 4.4 V8 so would the option be to get a set of 20" wheels or do you think the damage is already done
to the steering, or possibly look out for a 2007 steering rack and change that ?
Post #500260 Wed Jul 06 2016 2:43pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Before changing steering rack I would get tie rod ends checked
For play, also control arms, and also make sure sway/anti-roll bar links and bushings are connected and good.
If you brake hard on smooth surface do you hear any clunk ? Does wheel wobble at high speed ? Any competent suspension shop should be able to check this out for you ...
Post #500266 Wed Jul 06 2016 4:07pm
marka
Thanks Alpaca, will do
Post #500267 Wed Jul 06 2016 4:19pm
m3virus
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Check your tyre pressure or could need tracking👍 Current 55 reg 2.7tdvs with Hst extras
Post #500279 Wed Jul 06 2016 7:59pm
marka
Thanks
thats a good starting point, will do that tomorrow
Post #500280 Wed Jul 06 2016 8:03pm
Bodsy
Site Sponsor
Also check the ride heights. From the centre of the wheel to the wheel arch directly above it should be 466 rear and 465 front or thereabouts. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #500282 Wed Jul 06 2016 8:47pm
HemoRRS
You say you just brought it, was it private or from a dealer?
If it from a dealer I'd take it back to them and let them rectify it.
Post #500283 Wed Jul 06 2016 8:49pm
HemoRRS
Double post... Whistle
Post #500284 Wed Jul 06 2016 8:50pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Are the Lower arms ok 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #500287 Wed Jul 06 2016 9:13pm
marka
It was a private sale, the chap did say he had lowered the suspension by 30mm , would this make a difference ?
Post #500299 Thu Jul 07 2016 7:01am
Almost certainly, especially if he didn't get the alignment sorted out too. Even with the alignment done it'll probably still be bad.
Relatively easy to reset the ride height to the current settings to see if it helps. Alignment will need checking, of course.
On an 05, it's entirely possible that the suspension bushes and dampers are tired too, of course. 2012 SDV6 - it's missing a couple of cylinders
Post #500304 Thu Jul 07 2016 9:18am
marka
Thanks for all the info evryone, this is a great forum Thumbs Up
Post #500311 Thu Jul 07 2016 10:53am
Eaters
Resurrecting an old post as I’ve got a steering wander issue. Obviously I’ve had the alignment checked - it’s currently being looked at for the third time after having it up in the air to check all bushes and joints, which are tight.
Recently had the lower steering u/j done and I’m just wondering if the steering rack could be the culprit. The car is happy on a smooth level road but on any bump it makes a small adjustment in direction so that you are forever doing minor corrections. Travelling down narrow lanes this can be disconcerting.
Any ideas??? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #542905 Fri Dec 08 2017 12:16pm
