Home > Technical > replacing arb bushes front (rrs with ace) |
You don't need anything special other than a garage and patience to replace the front arb bushes. Your local garage should be able to do it without any real issues. |
Wed May 25 2016 11:59am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Unless the bolts are seized into the crossmember, which does happen more frequently than I would like, then it needs some (a lot of) heat...
Wed May 25 2016 7:33pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The frequency that my ARB bushes are changed, I'd be amazed if the bolts had time to seize... 2012 SDV6 - it's missing a couple of cylinders
Wed May 25 2016 9:39pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Having just replaced my ARB bushes along with complete new ARB too there is no way I would have attempted it without the two special tools (Thanks Dan @ Duckworths ) and a 15mm flexi head ratchet spanner
Wed May 25 2016 10:29pm |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
robp
Thu May 26 2016 6:00pm |
One of this set of Halford pro
Thu May 26 2016 9:19pm |
Thanks robp |
Fri May 27 2016 11:50pm |
Iceman08 Member Since: 09 Mar 2016 Location: Hereford Posts: 8 |
What are the two special tools please?! |
Tue Jul 05 2016 9:54pm |
Details of the part numbers and price from Dan at Duckworth in THIS thread
Tue Jul 05 2016 10:09pm |
Top man, thanks Rob
Tue Jul 05 2016 10:17pm |
The other thing I've read is there has been an upgrade to the clamps, is it worth changing these as well as the bushes?
Tue Jul 05 2016 10:22pm |
Mine was a full anti roll bar replacement so it came with new bushes and clamps but yeah if changing the bushes for first time I would change the clamp too TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Tue Jul 05 2016 10:37pm |
I do have access to a ramp but it's a bit tricky at the moment, so I was wondering if it's possible to change the bushes with it on axle stands?
Thu Jul 07 2016 9:32pm |
Yes its possible, If I can change the whole ACE ARB on a pair of axle stands then bushes are definitely doable though it is tight TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Thu Jul 07 2016 9:49pm |
