Home > General (L494) > Tyre wear in sawtooth pattern (Feathering ) |
I have 22" wheels and my tyres are hardly worn at all at 12000 miles, certainly no uneven tread wear patterns. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jun 27 2016 3:18pm |
DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283 |
Just make sure your pressures are correct in the first place. After that, get the dealer to confirm your geometry is correct.
Mon Jun 27 2016 3:31pm |
Alignment is out,,I have 22's on my sport & ive done 8000 miles on them & they all have 6mm of tread left & wearing even.
Mon Jun 27 2016 3:35pm |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
Off track a bit , I bought a car many years ago that was sold to me as needing a problem sorting wth the clutch. It wasn't the clutch that was causing the judder , it was all four tyres were at 22 psi not 2.2 bar.
Mon Jun 27 2016 4:05pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Which tyres have you got? I remember people used to complain about Continental tyres on L320 wearing at edges/feathering. It was classed as another "characteristic". Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Mon Jun 27 2016 4:29pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
Thanks for the replies,
Mon Jun 27 2016 4:41pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
My L320 TDV8 has feathered the front tyres since I bought it 5 years ago. Done it on 20in and 19in tyres. I think there's an inherent issue with the air suspension. The air suspension system allows a large tolerance in ride height on any given wheel. Ride height changes affect camber (although not toe it seems from experiments on the ramp) and changes in camber will affect tyre wear. We set the car to tight tolerance for the alignment and then normal tolerance for usual use.
Mon Jun 27 2016 6:09pm |
May I ask what type of four wheel alignment you have had?
Mon Jun 27 2016 9:01pm |
It's the Hunter system
Mon Jun 27 2016 10:30pm |
I was thinking that that different suspension heights must be having a impact on the tyre wear, but ours stay at one height during all on road driving.
Tue Jun 28 2016 8:47am |
