Home > Technical > Bad Wheel Bearing? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
Personally, initially I would try different make of pads before I started changing wheel bearings.
Sun Jun 05 2016 2:33pm |
Sound like a brake problem.
Sun Jun 05 2016 3:02pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
Normally the bearing noise would get louder if you turn right (for left bearing) - open the window , turn at 20mph and see if the noise gets worse. I had bearing issue - making a clicking noise - but there was no play when you tried to pull the wheel - shop told me it was not the bearing - I had them replace it anyway - fixed the problem - but on your case - could be sticking caliper or other issue as well |
Mon Jun 06 2016 12:56am |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
put some copper slip on the back of the pads, worked for me 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Mon Jun 06 2016 12:33pm |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
Warped brake disc might be the issue? 2010 TDV8 |
Mon Jun 06 2016 6:30pm |
