Home > Tips & Tricks > How to replace the front seat base foam |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
You can buy the parts for any year from a Land Rover dealer, mine dealer is quite close, only 20 mins or so by car.
Thu Apr 21 2016 10:09pm |
conno57 Member Since: 25 Apr 2016 Location: cumbria Posts: 9 |
hi,can you show how you actually remove the base to get to the seat bolts as mine need tightening . |
Fri May 27 2016 11:12am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
When you say the bolts need tightening, do you mean the seat moves slightly? This is a separate issue and requires the adjustment system to be altered.
Fri May 27 2016 5:12pm |
I concur, all 4 bolts would need to be very loose for you to feel the base moving!
Fri May 27 2016 5:54pm |
Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38 |
Great write up & how to! I will be attempting this myself soon, are the passenger and drivers seats the same i.e. interchangeable? 2007 Stornaway Grey RRS HSE 4.4 V8 |
Tue Jun 14 2016 6:17am |
Thanks! Pretty sure the metal bases and foam are the same, but the covers are left and right handed. The edges facing the centre console have a material pad on them, as opposed to leather, to stop the seatbelt 'sockets' squeaking against them.
Tue Jun 14 2016 8:26am |
The passenger seat, at least in the EU, has an occupancy sensor on it. This is sandwiched between foam and heating element layer. You'd need to swap the sensor or at least add one to the other base. The foam and base pan are the same though. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 14 2016 12:39pm |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 119 |
Hi The leather on the side of the drivers seat has worn and needs replacing so was going to put the passenger seat on the drivers side while its away for repair would the occupancy sensor cause any problems and what does it do
Sat Nov 12 2016 7:09pm |
Should be ok as a temporary solution. The occupancy sensor (a simple contact switch) tells the on board computer that someone is/not sitting in the passenger seat, and then you get the boings and flashing seatbelt light on the dash... |
Sat Nov 12 2016 7:29pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
If the seat has an airbag in it it will be on the wrong side. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Sat Nov 19 2016 11:24pm |
Do they have air bags in the seat base ? |
Sun Nov 20 2016 2:25pm |
Usually in the top outside if they are in the seats. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Mon Nov 21 2016 5:58am |
ShaunW Member Since: 09 Dec 2016 Location: Lincolnshire Posts: 4 |
Great how-to. Thanks.
Fri Dec 09 2016 7:16pm |
Have you considered this stuff ....https://www.furnitureclinic.co.uk/Leather_Colourant_Kit.php I bought a kit but haven't used it yet. |
Sun Dec 11 2016 5:36am |
