Home > Maintenance & Modifications > Which jack? |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
If you want to keep the cost down, use the scissor jack that came with the car and an axle stand or two- 3 tonne or above to be on the safe side. The 2 tonne affairs might hold the weight of a corner, but they are a bit small for the RRS! You should have the car on axle stands anyway if you're planning on doing anything more than swapping a wheel over.
Sun May 22 2016 9:42am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
I got mine from http://www.sgs-engineering.com/garage-equipment/trolley-jacks
Sun May 22 2016 10:23am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Don't use the LR-supplied scissor jack. It's an emergency-only item and has been known to fail.
Sun May 22 2016 3:16pm |
Oh heck! I used mine to change all 4 wheels to 19" ones, then back to 20's yesterday. I've got a Halfrauds 2 tonne trolley jack, but it isn't up the job of lifting the RRS, really feels like it's straining. Not high enough either |
Sun May 22 2016 3:38pm |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 |
Thanks for that link, just had a look at that site, what are people's thoughts on these? Will these lift it enough? Is 2.5 tonne strong enough?
Sun May 22 2016 3:49pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
Merc sprinter bottle jacks are good and you can get an adapt or to fit them made especially for the RRS. Lot of Landcruisers now sold
Sun May 22 2016 4:06pm |
as I mentioned,, I have the 2.5 ton,, rocket lift I think its called, it has a higher lift than a lot of jacks and certainly lifts the RS,,, only one corner at a time though. wouldn't like to risk lifting the whole front or rear, could be a tad wobbly !! 2010 RRS, TDV8
Sun May 22 2016 4:12pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
I've done the research on Disco3 forum.....
Sun May 22 2016 4:46pm |
The Halfords 3 tonne jack is identical to the SGS one; I wonder if have the same source.
Sun May 22 2016 7:30pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
I'm planning on getting this to replace my old 2 ton lift.
Sun May 22 2016 7:31pm |
Dan - that quick lift one has poor reviews on Disco3 forum. It buckles under load.....
Sun May 22 2016 8:04pm |
It has very good reviews everywhere I've read.hmmmm. Perhaps if it's buckling under load all I can see it must be on an uneven floor to begin with.
Mon May 23 2016 7:56am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
As above, that jack is not up to the job. I use the heavy duty version, which is excellent however. Visiting from DISCO3.CO.UK
Mon May 23 2016 9:17am |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Another vote for the Halfords 3 Ton trolley jack even better if you can find someone with a trade card
Wed May 25 2016 10:39pm |
