Home > Technical > Suspension problem |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Sounds like the start of EAS compressor failure it's located just in front of the near side rear wheel under the body - from start up get someone to lower - raise the suspension from within the cab. A good indicator is a noisy compressor if it struggles to raise quietly it will need more investigation but seems likely to be the cause of your issue.
Tue May 10 2016 10:46pm |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
Just been looking online and found pump piston repair kit
Tue May 10 2016 11:46pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
If you are really lucky like I was a reset of all fault codes cleared this fault, it was comming in on my one nearly every time I drove it but reset each time I turned the key on and off.
Wed May 11 2016 6:40am |
Not realising it was a problem I have heard the pump working for a while if pump is damaged will it be a garage job or diy as I have mechanic abilities and a iidtool to reset codes |
Wed May 11 2016 8:31am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
Its a DIY job and some good how to guides on Disco 3 forum (same car essentially)....I'm no expert but from my reading its best to get a new one fitted and not try and repair yours.
Wed May 11 2016 11:15am |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
I have the early type compressor on mine, which had the same issues that you are having. I bought the service kit, and replaced the pump piston ring etc. It's run faultlessly ever since.
Thu May 12 2016 8:21am |
Last night I cleared the fault codes then re wrote flash software to pump and body control ecu suspension semis softer as did get quite stiff feeling bumps more
Thu May 12 2016 5:50pm |
Hope it works for you but do keep us posted. Lot of Landcruisers now sold
Fri May 13 2016 6:47am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
DYI. I am planning to do it tomorrow on mine. Bought this kit: https://x8r.co.uk/land-rover-discovery-3-4...d-cap.html (has both all the seals and drier silicone, as well as the upgraded top cap, which very often develops a hairline crack and allows air to escape, resulting in symptoms as described). I plan to follow these guides: Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Fri May 13 2016 10:48am |
After my post yesterday I took car out and got the yellow light again so ordered repair kit from x8r which is due to arrive on Monday so will let you know how I get on |
Fri May 13 2016 8:55pm |
Quick update: I stand corrected.
Sat May 14 2016 3:58pm |
Fixed it.
Wed May 18 2016 9:52pm |
I have removed my compressor but 1 of the rear pipe connections was seised thus the pipe has snapped leaving the insert in the compressor not able to remove
Thu May 19 2016 8:53pm |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
the return pipes I just cut mine off and when refitting just joined them with rubber hoses spiteful Range Rover Sport tdv8 |
Thu May 19 2016 9:33pm |
