Home > Technical > 'Variable Effort Steering' - HEAVY STEERING! |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
could be the lower steering ball joint, mine went really heavy, and it is a known fault, the knuckle siezes up, its around £100 plus fitting for a new one 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Mon Apr 25 2016 4:47am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The steering is speed sensitive so the error could be related to that. The steering control is part of the air suspension control module which is located on the A pillar behind the steering wheel. Would be worth checking that there are no loose connections to the module. It's easy enough to access.
Mon Apr 25 2016 10:56am |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
Private sale or garage, if its the latter they should sort it for you as its a safety issue |
Mon Apr 25 2016 10:59am |
ezzycozzy Member Since: 19 Mar 2016 Location: Liverpool Posts: 6 |
Private sale from a business associate! (says the steering was always heavy due to the tyres) |
Mon Apr 25 2016 4:15pm |
You need to put some air in them then 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Fri Apr 29 2016 8:15am |
Had a guy look at it & was some kind of software issue. had that and the steering wheel column switch fixed for £200. The difference is unreal!! |
Mon May 02 2016 8:04pm |
Good result. It's nice when they're working properly! 2012 SDV6 - it's missing a couple of cylinders
Tue May 03 2016 9:54am |
