Home > Technical > Adaptive Headlights not dancing |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
YWC500440 according to the image earlier in the thread. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Jan 13 2015 10:50pm |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 |
On top of the headlight as you look at it from the front end are two Hex Bolts. The outside bolt adjusts the 'left to right' and the inside adjusts 'up and down' You will need a 6mm Alan Key which is at least 15cm long to reach the Hex bolt (cream/white in colour). Obviously park in front of a wall or garage to see beam when adjusting |
Wed Jan 14 2015 12:00pm |
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 41 |
I think that is the AFS Power module, and there are two, one on each headlamp. AFS control module, behind the CJB, is the part and number I am asking about. pelle |
Wed Jan 14 2015 12:13pm |
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 |
Thanks for that Micalee. I wil have a look at the weekend. Heres to seeing in the dark again! |
Wed Jan 14 2015 1:38pm |
tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36 |
have the same problem lights don't dance or move on turning corners. changed afs module on headlight still nothing fuse ok. I have 55 plate S/C thanks again for help and info. |
Sun Apr 19 2015 2:09pm |
Has someone with this problem fixed it until now? except robmeister1969.
Tue Feb 09 2016 11:19pm |
hi pelle still not fixed mine. did have a go as you can see in my last post. and pulled the lights apart when I done the led thing everything ok. but to be honest my dads rrs has got afs and its not that good really. but I would say its what robmeister1969 has done cheers. |
Wed Feb 10 2016 9:06pm |
I found the part number for the AFS ECU.
Mon Mar 07 2016 3:00am |
I changed my AFS ECU and my lights are dancing now. |
Sat Mar 12 2016 11:59am |
hi pelle was it difficult to do. whats the price for the ecu cheers. |
Sat Mar 12 2016 4:46pm |
robmeister1969 has described the process in an other thread in this forum.
Sat Mar 12 2016 7:20pm |
Dek Cross Member Since: 25 May 2016 Location: Livingston Posts: 1 |
Hi am having a similar problem RR sport 3.6 07 plate
Tue Aug 02 2016 9:47pm |
nich666 Member Since: 22 Jun 2017 Location: Toulouse Posts: 1 |
Hi all, I have a 2008 RR Sport with hazed over headlights Grrr. Does anyone know if these Hex bolts mentioned above adjust for a LHD? (I live in France). Looking at replacements I can't find out if British RHD ones are changeable to LHD. Mine are the normal bulbs AFS 'Dancing' lights. I know that later lights had a small lever to change over for LHD but cannot find anywhere if mine do. Another related issue is I am wondering if I found secondhand non AFS and fitted them would it upset the car as much as me. In that year RR fitted three different headlight systems, it's barmy. |
Thu Jun 22 2017 7:38pm |
CraigJ Member Since: 28 Jun 2020 Location: Aberdeenshire Posts: 1 |
Hi Guys,
Sun Jun 28 2020 7:20pm |
