Home > Maintenance & Modifications > Determining air compressor type |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
With the IID, select ECU Flashing > Suspension and choose the option to indentify the firmware. It's possible for the AMK to be fitted but the firmware not updated though, in which case you'd need to check under the cover AFAIK. Firmware is the same for either AMK version but it would be the original type available then, which is what I'd expect to have been fitted. Visiting from DISCO3.CO.UK
Fri Feb 05 2016 11:42am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
LfW
Sat Feb 06 2016 8:10pm |
Just bear in mind then that you may want to do a physical check then just in case the software hasn't been updated correctly. Visiting from DISCO3.CO.UK
Sun Feb 07 2016 10:45am |
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 |
Can I ask what make and grade of oil are you guys using in the tdv8s as will be doing mine soon.
Mon Feb 08 2016 10:20pm |
The Duke Member Since: 12 Aug 2015 Location: Brittany Posts: 10 |
Well that's been an interesting few weeks...
Tue Feb 16 2016 11:45am |
