Home > Technical > High Coolant Pressure |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Worked on a P38 RR with similar simptoms ended up being the water pump. Impels had broken up so the water wasn't circulating so overheated on anything but short runs.. 2008 G4 RRSport TDV8 current
Tue Feb 02 2016 11:27pm |
bazza d Member Since: 08 Nov 2015 Location: lincoln Posts: 11 |
Thanks for the reply Camelrock i will check the water pump out. i will let you know how it goes |
Wed Feb 03 2016 10:40pm |
Has anyone checked the radiator for partial blockage? That would produce the symptoms you describe. 2008 MY Java Black TDV8 HSE
Thu Feb 04 2016 10:58am |
Thanks Paddi will check it out |
Tue Feb 09 2016 10:54pm |
Thanks for the advice guys. sorry i have been a while getting back to you, i was getting nowhere so the garage i bought the car from agreed to take it back and run it for a few days to find the fault. it turns out it was the dreaded head gasket so body off and a week later and i got my car back.They completed the work under warranty. thank god ! and i took it out for a long run to the peak district last weekend towing our caravan with no problems at all so touch wood i hope that's the end of the problem.
Wed Mar 02 2016 12:26am |
