Home > General (L494) > Auto Start Stop
Page 1 of 3 123>
Bobajobbob
Auto Start Stop
Evening all, is there any way to turn off the auto start stop by default? I find it a massive pain in the ass.
Post #486235 Sun Jan 31 2016 11:30pm
anthony-apl
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
As far as I know you can only turn it off on each journey but I may be wrong. I just don't press the brake as hard when i'm stopped then it doesn't do it. 16 model year yulong white autobiography
Bentley continental GTC
2011 VW Transporter T5 Kombi 140BHP with sport line kit for work
15 model year black RRS HSE gone
11MY Fuji White 3.0 TDV6 HSE
Ivory premium leather
Ebony contrast stitching
Extended leather pack
Anigra Wood now gone
08MY Range Rover Sport TDV6 GONE
Post #486238 Sun Jan 31 2016 11:45pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Re: Auto Start Stop
Hope that someone can find a way to over ride this nonsense....
Post #486245 Mon Feb 01 2016 4:56am
wilf
Disconnect the auxiliary battery. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #486254 Mon Feb 01 2016 9:19am
Autobiography
I don't know why anybody would want to? What's the issue as I seriously don't have any problem - in fact I like the fact that I'm saving fuel when stationary.
And for those times you don't want it to work, either press the button or adjust your brake pressure accordingly!
Post #486260 Mon Feb 01 2016 9:59am
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Sorry, what button do you press ?
Post #486261 Mon Feb 01 2016 10:08am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Before I had the car I thought it would drive me silly: What's the point of Stop/Start in a 550 BHP 5L supercharged V8 for Christ's sake?
Now, approaching 15k miles, I think it works very well. What's wrong with it? As posted, being linked to the brake predal pressure you can use it or not at will, with engine stopped at traffic lights can start the engine when you see the lights changing, if you are in command shift having a bit of fun it doesn't activate, ...
The only thing that does sometimes get to me is that when stopped in traffic and you wish to lift off the brake pedal if you're blinding the person behind without the engine starting is the need to shift into neutral. I wish this cold be done by pulling both command shift paddles or similar.
First World problems hey. Very Happy
Post #486262 Mon Feb 01 2016 10:16am
Autobiography
The A OFF with a circular arrow round it in the suspension height switch pack
Post #486263 Mon Feb 01 2016 10:25am
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
I am also slowly starting to use it rather then turning it off. I like the way it turn the engine off and then when you take the seat belt off, also turns off the ignition.
Post #486288 Mon Feb 01 2016 6:30pm
Tim in Scotland
Easy way not to blind those following you by keeping your foot on the foot brake........... put the selector into N, engage the EPB and take your foot off the brake and the engine will stay stopped until you select D again. OK it takes a bit of practice with the timing but it works. I learned this trick with it when I had the Evoque and it works in the RRS2 too. I also thought I would reach for the off switch at every opportunity but now I never bother, as said by philmw it works really well and you do save some fuel using it............. and when I drive my defender into town I keep stalling it at the lights now I'm so used to the Stop/Start! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #486295 Mon Feb 01 2016 6:56pm
wilf
This annoys the living daylights out of me.
Often, when I stop, I need to make a note of mileage on my biz miles sheet. That liver on the back seat, and to get to it I have to undo the seat belt - and then the bl**dy car turns itself off before I have made a note of the mileage. Then I have to turn it back on and wait for the boot up sequence to finally end. It truly is the single most annoying feature for me. If I want to turn the car off, all I have to do is press a button, I don't want, need, or desire the software to decide to do it for me.
Same thing if I want to undo the seat belt to turn completely around to see where I am reversing. Bl**dy annoying. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #486314 Mon Feb 01 2016 8:49pm
Autobiography
Why don't you just use the InControl app for all your journey and mileage data?
Post #486315 Mon Feb 01 2016 9:04pm
mikef
Personally the auto stop/start drives me nuts principally because occasionally when I put the car into reverse, the engine stops and does not restart. I then have to put the car in Park and restart the engine on the button. The trouble is that this is intermittent and I have not been able to demonstrate the problem to my dealer. I have taken to switching the auto stop/start off before I put the gearbox into reverse. I know that auto stop/start is now fitted to most new cars but as far as I'm concerned it's not an answer to any question I asked
Post #486316 Mon Feb 01 2016 9:33pm
PetesRRS
Australia 2013 Range Rover Sport SDV6 HSE Fuji White
Yes it can be disabled. I have read on US Forum how this can be done. They say you simply have to disconnect the positive terminal on the small battery behind the right hand rear panel. Have I done it No as the auto start stop does not a annoy me and besides I have a finger that can push buttons if required. Thumbs Up
Post #486351 Tue Feb 02 2016 6:03am
wilf
Because I will simply forget if I don't do it at the end of a journey, that is my routine and dammed if I see why some stupid software should make me change it. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #486355 Tue Feb 02 2016 7:10am
Page 1 of 3 123>
