Home > Maintenance & Modifications > Front Dynamic Anti-Roll Bar Replacement |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
I believe it's a body off job - or at least a body lift-a-bit anyway. 2012 SDV6 - it's missing a couple of cylinders
Sun Jan 31 2016 12:22pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Yes the ACE ARB Bush clamps have 3 bolts on each. And the rear one is imposible to get a socket onto it. So i think its a body lift job. itisme |
Sun Jan 31 2016 12:56pm |
Just had a look at the manual. Assuming you have a 4.2S/C, I've extracted the procedure and put it here:
Sun Jan 31 2016 1:07pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
Front or rear bar? |
Sun Jan 31 2016 2:04pm |
I was refering to my Front Bar, I understand the rear
Sun Jan 31 2016 2:09pm |
Chilly07 Member Since: 25 Dec 2015 Location: Central Coast, NSW Posts: 24 |
Oops!
Sun Jan 31 2016 3:26pm |
Undo ARB links
Sun Jan 31 2016 3:39pm |
You make it sound so simple! 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 01 2016 9:55am |
Thanks for this information. Ill be giving it a go Tuesday!! |
Mon Feb 01 2016 2:30pm |
Well....started this morning. Followed Disco-Mickey advice. Definitely take wishbone off...so easier.
Tue Feb 02 2016 2:24pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Just about to do this myself and am ordering all the parts.
Thu May 05 2016 2:40pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
would of what??
Fri May 06 2016 10:43pm |
Sorry fat fingers and small phone keyboard don't mix!
Fri May 06 2016 11:09pm |
The bleed nipples are on the ends of the big drum part of the anti roll bar. One at each end and they at the top between the bolts that holds the thing together. Not sure how you bleed it without LR's magic box though. 2012 SDV6 - it's missing a couple of cylinders
Sat May 07 2016 11:53am |
