Home > General > Anyone know what this is?
J2D
If I get this enabled, is there any way it will affect my LR warranty?
Post #483578 Wed Dec 30 2015 5:21pm
Disco_Mikey
No reason why it would invalidate anything. It is an optional extra Thumbs Up
Post #483590 Wed Dec 30 2015 7:22pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
On my previous 2012 RRS I had timed climate & Remote FBH option fitted & enabled retrofited soon after I bought it, and had no problems with LR warranty side of things. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #483611 Wed Dec 30 2015 10:48pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
J2D wrote:
RRSTDV8 wrote:
J2D wrote:
Why would this be fitted but not enabled? Seems strange
Are these fitted as standard on a 2011 HSE?
The heater unit is fitted to all diesels and is used automatically by the car to help attain and maintain engine temp in cold weather. You can hear it running at times.
Ah that makes sense. Yes I have heard something running in cold weather
Any idea where I can get this activated in the Essex area?
And would doing so affect my 2yr LR warranty?
I had mine activated at Les Paul Eastern Ave Woodford £50 For the Timer on satnav screen. I bought the Remote and receiver and aerial for remote operation, and fitted them myself. really worth having it done. Car can be warmed and de iced whilst you have your breakfast. As for your warranty, it will be no different than if it was done at the factory when new Thumbs Up Thumbs Up Thumbs Up itisme
Post #483682 Fri Jan 01 2016 10:28am
pots1968
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
How difficult is the fitting of the remote / arial and stuff ..? also where do you purchase the unit to make it work...
Ive got the timed climate enabled by Bodsy a while back ....
have a 2010 sport ...
cheers
Post #483869 Sun Jan 03 2016 11:16am
Darbs
Does anyone do the activation and remote for this in the Cheshire area ?
Rich Confused
Post #483871 Sun Jan 03 2016 11:44am
DrRob
Bodsy can do all that for you...... Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #483892 Sun Jan 03 2016 3:09pm
harrygh60
have a 2010 HSE
cheers
I bought my Receiver and Ariel from Landrover Yeovil Somerset. Mention RRS Forum, i paid £165. Including postage,18 Months ago. And bought the remote on Ebay £20. The receiver fits behind O/S panel in boot, There is a cable with a plug to connect to, and a bracket for the receiver to clip into, the Ariel sticks onto the inside of the rear quarter panel . I cant remember the correct procedure for the remote setup. But it was very easy, Just a case of removing a fuse in the engine compartment, and putting it back. Believe it was 2nd from top ? Have a look in my Gaallery there are pics of bits and where they go. I don't know how to get them onto this thread Big Cry itisme
Post #483954 Mon Jan 04 2016 10:13am
duvl
Please excuse my ignorance here as I'm very new to RRS. I took delivery only 3 weeks ago of a new 15.5 MY AB 4.4 (cancelled order from much earlier in 2015). I'd spotted on the spec printout from Topix ......Fuel Fired Htr.... I'd guessed what it might be referring to (FBH) but since the option at £1k was not on the invoice and the fact that the salesman didn't know what it referred to, I dismissed it, until this thread showed up. Under the hood I can't see anything resembling the op pics but am now hopeful a retro fit of the necessary bits can enable its use. Am I on the right track here and can anyone, preferably via a pic, show me its location on a similar/same RRS as mine? Just want to confirm I have a FBH before contacting an expert. Many thanks. RRS 4.4AB 15.5MY Fuji/Ivory
Thinkware F750 front/rear dashcam
Post #484019 Mon Jan 04 2016 9:44pm
duvl
Continuing from my post above I visited LR and posed the que's myself to a mechanic. He said that the Fuel Fired Heater and the FBH are two different things. At this point I'd resigned myself to not being able to upgrade to remote heating. He then pointed to what I've shown in the pics (see gallery) followed by the line that he had heard it's possible to 3rd party enable remote heating using this....hope returned.....but I began to have suspicions re his knowledge on the subject, so really I'm non the wiser. Beginning to think I'm way off track here and so I'd still appreciate some wise words in light of the above. Thanks RRS 4.4AB 15.5MY Fuji/Ivory
Post #484213 Thu Jan 07 2016 12:30pm
Disco_Mikey
Bodsy looked into this a while back, and the RRS2 is not as simple to retrofit RPH or TC...
Post #484250 Thu Jan 07 2016 10:18pm
Bodsy
Site Sponsor
Rich Confused
I can do this for you. Will drop you a message. Thumbs Up
Pots1968, quite straight forward to fit. 👍 I can talk you through it.
Duvl, if you don't have timed climate on the screen, then the FBH and associated plumbing will not be fitted so even though I can enable it for the fans to come on, there is no FBH to use as a park heater.
You can retro fit (at least it can be enabled) but there is the minor problem of
Additional wiring and pipework to fuel tank separate pump for FBH
From ther to the engine bay, additional wiring for FBH
Additional pipework for FBH water circuit as well as additional valve.
If the body had to come off for some reason, that would be the time to retro fit it.......
Is the tdv8 a 4.4 now or do you have the petrol engine? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #484257 Fri Jan 08 2016 1:31am
Lost for Words
The TDV8 has been 4.4 since 2011. Wink Visiting from DISCO3.CO.UK
Post #484266 Fri Jan 08 2016 10:06am
harrygh60
Si5974 wrote:
I contacted Bodsy to enable timed climate on my car, he did it the following day and I've used it loads of times since - it's a really useful function and I love it Thumbs Up
I opted for the remote control as well, so when I'm having my morning brew I turn the heater on while I'm sat in the house. Apart from the benefits of an already warmed engine it definitely takes the chill out of the interior.
Haven't tested it on a heavily iced up windscreen yet so not sure how effective it will be - but based on the interior temp I expect it to clear the windscreen without any problem.
I looked out of the window this morning and saw my Blue car had gained a contrasting White Roof and Bonnet.( Thick Frost.) That was when I really missed my RRS, with remote FBH. On mornings like this, a press of a button. 15/20 mins later, And a car with clear windows and on opening the door feeling the welcoming warmth Big Cry Big Cry Big Cry itisme
Post #484269 Fri Jan 08 2016 10:15am
duvl
Thanks Bodsy and others. What I've gleamed from this is that those that the upgrade was an easy fix, both parts wise (ebay) and IID tool option wise, had pre RRS2 cars. A 'body' removal is a step too far and so as I thought it's a non starter for me. The quick fix suggested by this thread sounded too good to be true. Thanks for putting me straight...perhaps the next car then Laughing RRS 4.4AB 15.5MY Fuji/Ivory
Post #484295 Fri Jan 08 2016 4:57pm
