Home > Wheels & Tyres > Quick wheel alignment check with measuring tape |
Its not just the fronts you need aligning,,you have to align the fronts with the rears.
Tue Dec 15 2015 7:29pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
the rears are dead centre 0 toe in |
Tue Dec 15 2015 7:32pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
I would think that what Tyrefitter is on about is the front axle (tyres) aligned with the back axle.
Tue Dec 15 2015 8:51pm |
You need to get the settings for aligning vehicles,,just doing the fronts is ok as long as you align to rears & it's all about the thrust angle,not just measuring the fronts with a tape measure.we use to get away with that idea year ago when nearly all vehicles had a starlight beam axle but now with so many agustments you should let someone do it on a 4 wheel alignment machine to get it accurate.
Tue Dec 15 2015 9:13pm |
off course the 4 wheel alignment is the best solution but I don't have time to pass by the shop to have it done.
Wed Dec 16 2015 11:17am |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
I'm looking for 4 wheel alignment in Leeds, I've read a few previous posts and googled it which is enough to give you nightmares about people with all the gear but no idea, anyone used a company in or near Leeds and happy with the result |
Fri Dec 18 2015 9:46pm |
