Home > Wheels & Tyres > 285, 50 x20 tires |
I believe there are guys on the Disco forum that run this size but no idea on a sport. I would imagine that your problem would be when going lock to lock that it would rub hopefully someone more experienced will be along to help you out soon 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Wed Dec 02 2015 9:46pm |
hairy bum Member Since: 20 Mar 2012 Location: glos Posts: 12 |
Thank you I hope so
Thu Dec 03 2015 11:34pm |
Oz Sport Member Since: 06 Jul 2011 Location: Perth Posts: 15 |
Hey Mate
Fri Dec 04 2015 3:22am |
Fantastic thank you for your quick reply I will look back through & have a look |
Fri Dec 04 2015 11:08am |
Just a thought do you think a wheel spacer would solve the rubbing issue ? Say 20mm or do you think it would make the tyres stick out past the arches far too much ?
Wed Dec 09 2015 10:17pm |
I didnt have a matching spare so couldnt tell you.
Thu Dec 10 2015 5:06am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
Assuming a Facelift spare wheel well is the same as a Pre Facelift then a 285/50 x 20 wheel/tyre will not fit. I managed to squeeze in a 275/45 x 21 but needed to use a Hacksaw and Grinder to do it(Not on the wheel I hasten to add). A 275/45 x 21 is approx. 781mm diam. and a 285/50 x 20 is 793mm. you would need to either cut away some of the Rear Cross Member or Rear Tie Rod Mounting Brackets or whatever there called possibly both. Cheers Col |
Thu Dec 10 2015 6:54pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
I've squeezed a 275/65R18 up into the spare well (albeit fully deflated and with a lot of swearing), and that's 814mm diameter. So I wouldn't think there'd be too much involved in fitting a 285/50R20 (793mm). I removed the heat shield and as mentioned, deflated the tyre - no need to cut anything.
Fri Dec 11 2015 1:50am |
I can see why people stick to 275x45 I don't mind a little bit of a Challenge , what could possibly go wrong
Fri Dec 11 2015 8:55am |
Am I missing something here? as I am under the impression a spare is carried in case you damaged a wheel or puncture a tyre, it seems a pretty pointless exercise to carry a totally deflated spare unless you carry a compressor or some means of inflating it as well. There is no way on earth you will get a fully inflated 285/50 x 20 into the space without modifying something. To get in a 275/45/ x 21 (781mm diam.) fully inflated. I had to grind and smooth off the weld where the tow hitch receiver is welded in to the rear cross member, reshape the heat shields and grind and re-shape the rear tie rod brackets slightly where they are welded to the rear sub-frame this is due to the increased Radius of the new inflated size wheel/tyre. Cheers Col |
Fri Dec 11 2015 11:04am |
Oh dear that's not good .. Now I understand why most people go for the 275-45's instead .. This looks like a lot of work |
Fri Dec 11 2015 2:52pm |
It really isn't as hard or difficult as it sound's just a lot of trial and error i.e up and down with the wheel until it fit's in. I think the main issue would be not removing to much from the rear tie bar bracket's, although they are quite substantial I would be concerned that removing to much would weaken them, although saying that I did mine some time ago and have checked them regularly as a precaution and have no issues.
Fri Dec 11 2015 3:19pm |
Double post. |
Fri Dec 11 2015 11:34pm |
I always have my compressor in the car as I am regularly off the road.
