Home > Technical > CRUISE CONTROL - SPEED CHANGES
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Hi, Had a seach on the forum but couldn't find anything on this issue.
I have a 2006 RRSs/c that I have had about a year now. Haven't had much need to use Cruise Control until a recent trip of approx. 1700klms.
Our max.speed limit is 110kph. When set on this speed the actual speed(GPS) varied from between 102 and 118 kph. Rolling Eyes
Yes it did vary depending on the terain.
I have other vehicles where the cruise control only varies 1 or 2 kph. One has the same ZF auto 6spd.
Is this normal for a RRS Question or is there somethig wrong with mine Question
Any feedback would be appreciated as I don't want to get booked for speeding especially when I don't even have my foot on the accelerator.
Post #476673 Fri Oct 16 2015 9:12pm
Can't say I've had the same problem with the ACC on my TDV8. Seems to hold speed pretty stable. 2012 SDV6 - it's missing a couple of cylinders
Post #476679 Fri Oct 16 2015 9:37pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Mine is an SDV6 but it holds speed within a couple of K's but will over speed on a steep downhill run.
Southbound on the M1 (F3) into Sydney near Hawkesbury Bridge for example.
Regards,
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #476825 Sat Oct 17 2015 8:00pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Mines pretty useless on downhill '30s' I must admit.
Post #477060 Mon Oct 19 2015 6:38pm
CRACKA
Sorry Fellas if you think I was exaggerating with those speed changes.
I just realized I was.
When the speed kept going up downhill I kept pushing the minus button and of course when it got to level ground it adjusted to the new lower speed. Rolling Eyes
So it means that it gained about 6-8kph down hill. Still not that good when your trying to keep to the speed limit.
I was speaking to my Auto Trans Specialist and he said its a common problem with the 6spd & 8spd Autos in heavier cars etc. "There isn't enough engine/trans breaking available."
Any comments on that theory Question
Post #477494 Fri Oct 23 2015 7:35am
Barryp
Cracka,
When running downhill (a long downhill) in cruise control mode I flick my auto into sport mode and change down a gear. Provides some engine braking and holds back the speed. M3 (110K speed limit) decent to the Moonee Bridge is another place where cruise control in drive mode runs away. Moonee decent requires dropping 2 ratios to limit speed as its pretty steep.
Regards
Post #477512 Fri Oct 23 2015 9:45am
Lost for Words
Piffle really. Thumbs Up
The transmission does limit the amount of negative torque permitted, but at the end of the day, the car has access to full braking should it need it so it's not really an excuse. Wink Visiting from DISCO3.CO.UK
Post #477516 Fri Oct 23 2015 10:15am
CRACKA
Thanks Fellas I'll give the sports mode a try next time, that will at least cut out the overdrive .
Post #477591 Sat Oct 24 2015 3:27am
