Home > Maintenance & Modifications > Bonnet switch replacement or bypass.
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hey guys.
This Bonnet Open message and car alarm of mine is driving me mad.
Has anyone bypassed or replaced this bonnet switch that they can help me with?
Gaz. I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #471826 Thu Sep 03 2015 8:14am
Lost for Words
Stick a paperclip in the connector. Thumbs Up Visiting from DISCO3.CO.UK
Post #471828 Thu Sep 03 2015 8:27am
I replaced mine last weekend following a few alarm activations and a spurious "bonnet open" message. £25 for the whole latch/switch from LR dealership. Quick and easy to do. You need a T30 torx bit and a small flat bladed screwdriver. I took off the grille and driver's side headlight to give me room but you could probably do it without doing that. Two torx bolts to undo and used the screwdriver to ease the release cable off the latch. Undo the electrical connector and that's it. Replacement is just as easy and the bolts are 10Nm / 7lbft although I don't have a small torque wrench so just nipped them up. I spent a few moments checking that it locks and releases cleanly.
The old latch is stamped FoMoCo, the new one isn't. The new switch is different which is presumably why you can no longer just buy the switch separately.
Along with the boot switch, this must be one of the easiest fixes on a Sport! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #471836 Thu Sep 03 2015 9:29am
Gaz
Great!....many thanks Thumbs Up
EGR Blanked.
Post #471841 Thu Sep 03 2015 10:33am
Gaz
.....how would I go about doing the paperclip thing in the meantime?
I'm confused on where abouts it goes.... Whistle
Gaz I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #471880 Thu Sep 03 2015 6:50pm
Lost for Words
Unplug the connector and stick the paperclip in it. Thumbs Up Visiting from DISCO3.CO.UK
Post #471882 Thu Sep 03 2015 6:58pm
Gaz
.....aha....right....will take a look today!
That's what I love about you....you're so concise!...lol
Gaz. Thumbs Up Laughing I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #471928 Fri Sep 04 2015 6:43am
I found the electrical connector quite difficult to remove until I released the whole catch from the slam panel. 2012 SDV6 - it's missing a couple of cylinders
Post #471933 Fri Sep 04 2015 8:06am
Lost for Words
Pic here for you (courtesy of Robbie). Would have explained a little further last night, but was rushing off. Thumbs Up
Basically, the circuit is closed when the bonnet's shut, so the paperclip completes it - useful for drain testing. Wink
Interesting. Had no trouble on the D3. From memory, I wouldn't have thought access would be any more difficult on the RRS. Ah...was it the ACE reservoir in the way? Visiting from DISCO3.CO.UK
Post #471939 Fri Sep 04 2015 8:52am
The ACE reservoir is in the way a bit but I just found the connector was very stiff to move. Once I'd got a couple of mm of it out it popped out easily enough. Just found that I had to press the release catch bit and use a blade to lever it open slightly. Some connectors seem to be that way - the one for the heated rear screen was an absolute Censored to open, for example. 2012 SDV6 - it's missing a couple of cylinders
Post #471961 Fri Sep 04 2015 12:33pm
Gaz
Lads.....you've been so helpful...thanks.
Deffo going to sort it this weekend.
Yes, the ACE bottle is tight up to the catch but I'm sure I can do it.
I have fingers like sausages though!!
EGR Blanked.
Post #471986 Fri Sep 04 2015 3:49pm
Gaz
Sorted it today!....thanks guys!
It was actually quite easy. It's just the connector is a little awkward to access.
EGR Blanked.
Post #472108 Sat Sep 05 2015 10:42am
So a "bodge" repair then? Whistle Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #472128 Sat Sep 05 2015 5:39pm
Gaz
.....ahem.....yes! Rolling with laughter
(Until I get around to ordering a switch!) Thumbs Up I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #472136 Sat Sep 05 2015 6:25pm
