Home > Technical > Front parking sensor aid inactive on dashboard |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Welcome to the Forum - do you still get the bleep? one long continuous bleep ? with the error message ? .Common fault - the sensors don't last forever - if you get the bleep - it's a sensor. Ideally you need a diagnostic tool to read the recent error codes this can identify the offending sensor location. Mine used to dry out therefore work & then stop when it rained causing intermittent problems.
Wed Jan 08 2014 10:37pm |
Grimps42 Member Since: 28 Oct 2013 Location: Norfolk Posts: 23 |
Hi peachy
Wed Jan 08 2014 10:44pm |
Chechen fuse 36, 5 amp fuse parking sensors it was good? Do the control module have separate fuses? |
Wed Jan 08 2014 10:46pm |
Try this
Wed Jan 08 2014 10:53pm |
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 |
Peachy is the best!! |
Fri Jan 10 2014 3:39pm |
fredouille Member Since: 05 Jun 2011 Location: BORDEAUX Posts: 13 |
hello,
Sat Jan 11 2014 9:01am |
Thanks very much, just need to find the part number now? |
Sat Jan 11 2014 9:41am |
LR006482 |
Sun Jan 12 2014 11:26pm |
rumz Member Since: 06 Nov 2014 Location: Horley, Surrey Posts: 101 |
Hi All,
Wed Jul 15 2015 6:42pm |
Anyone? |
Thu Jul 16 2015 3:08pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
A damaged/corroded loom would not be unlikely. Visiting from DISCO3.CO.UK
Thu Jul 16 2015 3:21pm |
Thanks mate,
Mon Jul 20 2015 9:45pm |
