Home > Maintenance & Modifications > EAS Calibration with IIDTool, but car is to low or not? |
rhenus132 Member Since: 13 Jun 2015 Location: Kaltenengers Posts: 34 |
Mon Jun 15 2015 12:18pm |
Frank, follow the instructions in the manual for the IID tool, there is a calculation sheet in there. Follow it exactly and it will fix your problem. It evene mentions what the heights should be.
Mon Jun 15 2015 12:20pm |
thanks for fast reply...
Mon Jun 15 2015 12:24pm |
When I sit inside the car. Where is a b c d position? |
Mon Jun 15 2015 1:55pm |
Not being funny, but have you looked at the calibration sheet.......?
Mon Jun 15 2015 4:41pm |
Wer did you find this?
Mon Jun 15 2015 9:29pm |
Are you looking at the D3 spec or the RRS spec....? Bodsys Brake Bible
Mon Jun 15 2015 9:36pm |
Range Rover Sport 2006 TDV6 |
Mon Jun 15 2015 9:37pm |
You know what, I cant find it again. It's not in the newer manual..... Bodsys Brake Bible
Mon Jun 15 2015 10:05pm |
PatGapInnov Member Since: 30 Jul 2012 Location: Montreal Posts: 42 |
There is an error in the IIDTool user manual and I will make the correction Bodsy's right:
Tue Jun 16 2015 6:51pm |
Bodsys Brake Bible
Tue Jun 16 2015 6:54pm |
thanks a lot..!!!! |
Tue Jun 16 2015 7:27pm |
i have done all steps and now the failure is gone...
Thu Jun 25 2015 9:42pm |
drop it 10mm and drive. then drop another 10mm and drive, then drop 1mm increments until you get fed up with the ride and put it back to original... Bodsys Brake Bible
Thu Jun 25 2015 9:47pm |
Bodsy's spot on. Keep in mind that if you lower it too much, the access height will become unusable as in:
Thu Jun 25 2015 10:12pm |
