Home > General (L494) > Y14 FNA Warranty discs, calipers,windscreen, |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 |
[list=]
Mon May 18 2015 8:09pm |
AHHHHHRRGH!!
Tue May 19 2015 4:09pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8853 |
I'd be handing that back and demanding my money back. With that list of issues Land Rover don't deserve your money! 2012 SDV6 - it's missing a couple of cylinders
Tue May 19 2015 6:24pm |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 |
ok, stupid question time. what is FBH blip? and do i need it? is it free or standard on an autobiography?
Tue May 19 2015 6:40pm |
this way as I have had full underside inspection on the ramp!! the car will be as it should have been, after all its a car and everything can be put right, work the system and the results can be amazing once correctly fixed. this is nothing new, not the first time with LR either, but there is brands out there who certainly would not go the extra mile to address and fix it to the customer satisfaction. this makes the difference, even if it doesn't get done quite to plan, better right than going back again and again, even though I have had to do this 3 times to get it resolved. 3 times back to get years of hassle free motoring is worth it in my book. plus they know when you come in to be on there toes and get the top techs on the car to avoid issues. None currently Gone rejected RRS autobi Dynamic MY14.5 (Peter Vardy 👎) D3 XXV full conversion 4.2 SC FFRR 4.4 FFRR Freelander 1 |
Tue May 19 2015 8:10pm |
the blip is if you had factory fitted Remote fuel burner heat system installed. it can have up to 4 blips programmed per car. None currently Gone rejected RRS autobi Dynamic MY14.5 (Peter Vardy 👎) D3 XXV full conversion 4.2 SC FFRR 4.4 FFRR Freelander 1 |
Tue May 19 2015 8:11pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
Work being done at Vardy Aberdeen? 2022 P440e AB |
Tue May 19 2015 9:03pm |
Yip getting fixed at Vardy Abz
Tue May 19 2015 9:15pm |
Let us know how you get on.... I've moved on to Ogg's... Just tired with a few things...
Tue May 19 2015 9:20pm |
The service side is okay, just need to get the boss on side
Tue May 19 2015 9:25pm |
Car back all fixed today finally,
Wed May 20 2015 4:58pm |
Thu May 21 2015 10:44am |
Well can't thank the Peter Vardy service manager Darren enough,
Thu May 21 2015 11:08am |
trevleg Member Since: 22 May 2015 Location: Bordeaux Posts: 1 |
I have had my discs replaced 4 times in 20000 miles on a 2014 RRS SDV8 autobiography dynamic with 12k option list. I waited 7 months for this car . the hubs bearings were changed twice but they have not changed the Calipers or the carriers yet it still vibrates under braking.
Fri May 22 2015 12:29am |
