Home > General (L494) > Head Up Display
Mark_N
Head Up Display
So, for those of you with this option, is it worth the £1000? Is it readable/useful/distracting? During the day/at night? Can you see it with polarising sunglasses on? I didn't specify for my car but haven't seen any comments on it. Mark
SVR in Estoril Blue Thumbs Up
Post #459718 Sun Apr 19 2015 9:58am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I think it's great. Driving the SVR at 30 or 40 mph is not easy, and having the speed and current speed limit in front of you is a huge benefit. Haven't tried with glasses yet (ordered some Serengeti blue matching shades yesterday Smile ). Only done one trip with the sat nav on, and I knew where I was going, so can't comment on the helpfulness of that. It also displays the forward alert symbol, which is a good thing.
A great option.
Post #459720 Sun Apr 19 2015 10:02am
Mark_N
Thanks, in theory, reflected light is plane polarised so polarising sunglasses may block out the light but will be interested to hear how it is with them. I agree the SVR is difficult to drive within the speed limits, I use the speed limiter just for this purpose. Mark
Post #459722 Sun Apr 19 2015 10:15am
philmw
Yes, the reflected light from the HUD will be polarised. What gets through the glasses will of course depend on the orientation of the polarised lenses. Some glasses have this at 45 degrees. Some driving glasses, through, are oriented to cut reflections from the road, which would also cut the HUD.
I'll have a play with different types later today. I'll try and capture some photos/video.
Post #459725 Sun Apr 19 2015 10:37am
Autobiography
I have this on my L405 and think it is useless in daylight. It's been in once for 'adjustment' and is no better.
Do you guys suffer from 'washout' in daylight? I can barely see it on max brightness!
Post #459726 Sun Apr 19 2015 10:46am
philmw
Fine on mine. Mine is too bright when turned up.
Post #459731 Sun Apr 19 2015 10:55am
philmw
So, in real life the HUD appears slightly brighter than displayed in a photograph due to the slow refresh rate of the HUD compared to the shutter speed (and why I haven't made a video yet as my proper video camera is too bulky to set up quickly), but:
Photograph of view in daytime with the sun behind cloud (and ignore the uncut grass to the right):
Photograph on the move ( Embarassed ) showing speed, limit, cruise set speed, follow mode, and sat nav directions:
Photograph when the sun is out:
Back at base. Photograph showing view:
then looking back through a lens of a (cheap) pair of polarised glasses when oriented correctly:
then with the glasses rotated through 90 degrees:
Post #459758 Sun Apr 19 2015 3:08pm
Mark_N
The sunglasses rotated through 90 degrees improve the contrast.... but it does look like normal orientation blocks out the light.
I assume the optical system makes the display appear at close to infinity so it's in focus when looking at "stuff" through the windscreen and you don't need to refocus on the display. Mark
Post #459760 Sun Apr 19 2015 3:28pm
philmw
Yes, driving with your neck bent 90 degrees would appear to help greatly. Confused
The point of focus I presume is in front of the windscreen by the same distance the HUD unit is away from it, 12 inches at most. The second photograph support this
Post #459762 Sun Apr 19 2015 3:33pm
Mark_N
I expect the optics are such that the image passes through a collimator which will make it appear to come from infinity or at least a distance rather greater than the actual projector-windscreen distance; otherwise having to refocus from the road to the display - as you have to do with the instruments - will be quite tiring on the eyes.
That for me would be the major benefit but I haven't seen it so cannot be sure. Certainly, in an SLR camera, the eye-piece optics make the focussing screen appear much farther away than it actually is which is why short-sighted people like me cannot see the detail without their distance glasses on. Mark
Post #459766 Sun Apr 19 2015 4:35pm
philmw
I can confirm that all polarised glasses I've tried are oriented so they cut out almost all of the HUD light. Also, TFT displays are also polarised and sure enough bits of that disappear too Confused
Post #460277 Thu Apr 23 2015 7:55pm
eddkawasaki
I spent about an hour in the Oakley vault at Cheshire oaks yesterday trying to find a pair of non polarised glasses that I like. Both of my current sunglasses are polarized.
Post #460288 Thu Apr 23 2015 8:38pm
philmw
I am stuck with a pair of Serengeti 555 nm lenses as they reflect blue light that matches the car. Rolling Eyes
Post #460290 Thu Apr 23 2015 9:00pm
eddkawasaki
I haven't had any issues with viewing the tft screens in the Evoque even the dual view works ok with my Oakleys.
Post #460295 Thu Apr 23 2015 10:04pm
philmw
TFT and centre screen are polarized at 45 degrees.
Post #460329 Fri Apr 24 2015 12:25pm
