Home > Detailing & Car Cleaning > Power washing the engine
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
We have a 2011 RRS 3.0 TDV.
The engine and bay are in need of a good clean. Is it ok to use the snow foam and then power wash or not?
Kind Regards
Frank
Post #457455 Sat Mar 28 2015 7:20pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
i did mine but was very careful not to aim lance around battery /ecu area,personally i wouldn't do it again knowing what these cars can be like...just take the plastic cover off and give that a good clean would make a big difference Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #457458 Sat Mar 28 2015 7:44pm
chatuge
Absolutely fine to do. Buy a good degreaser like R222 total auto wash. Then turn the engine on, spray the engine bay with the R222, then jet wash the engine bay whilst the cars running. Then shut the bonnet and leave running for 20 mins to "cook" off any water! I do mine every month and have been for around 3 years - never had a prob yet!
Post #457460 Sat Mar 28 2015 8:18pm
Si-W85
Would it be ok to do with the SC engine?
Post #457461 Sat Mar 28 2015 8:34pm
chatuge
IN my opinion it'd be safe to do it on any engine! I've got 5 cars and do it to all of mine. Never had an issue.
Post #457463 Sat Mar 28 2015 8:53pm
Si-W85
Cheers will give it a go, I have bought some engine bay detailer as I thought it was due a spruce up so might just lightly snow foam and rinse clean Thumbs Up
Post #457464 Sat Mar 28 2015 8:56pm
chatuge
The trick is the degreaser! Use a good degreaser and it won't need anything else (in my opinion!).
Post #457465 Sat Mar 28 2015 8:57pm
Si-W85
I have some Autoglymm engine degreaser/cleaner which I will try out then as it was a recent buy from halfrauds in there 3 for 2 cleaning deal
Post #457466 Sat Mar 28 2015 9:07pm
chatuge
That will be perfect. I personally would use that and then nothing else. The engine dressing products end up attracting dirt to them.
Post #457467 Sat Mar 28 2015 9:13pm
Si-W85
Is there anywhere I should stay well away from? Not sure where the ecu is on mine but will be inspecting before I do it. Also is it better with engine running or not as wouldn't want to short any electrics that will be on while the car is running :/
Post #457471 Sat Mar 28 2015 9:18pm
chatuge
I always always have engine running. Remember that your engine gets wet when you drive it anyway so this is ok to do! I constantly move the jet wash so that no direct water in a concentrated dose can hit anything too long.
Post #457472 Sat Mar 28 2015 9:20pm
Si-W85
Cool will do it tomorrow, thanks for the advise Thumbs Up
Post #457473 Sat Mar 28 2015 9:23pm
The engine ECU and the transfer box ECU are in a box behind the battery. There is a cooling fan built in to the ECU box so you probably want to keep any water away from that area - it's behind the battery so you'll likely be careful of that area anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #457476 Sat Mar 28 2015 9:41pm
fdhadi
Thanks for all the replies. Got some Auto Glym Degreaser from the local factors so will go and give it a try!
Regards
Frank
Post #457514 Sun Mar 29 2015 11:36am
fdhadi
Job done & happy with the result.
Thanks again Wink
Frank
Post #457567 Sun Mar 29 2015 10:17pm
