Home > General > Timing belt change on TDV6/8 |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
TDV6 105000 miles or 5 years, whichever sooner.
Wed Mar 18 2015 4:42pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
TDV6 is 105k or 7 years.
Wed Mar 18 2015 4:45pm |
You are correct lfw, I was too focused on my chains! Sorry about that, last time I offer technical advice. |
Wed Mar 18 2015 4:53pm |
Not at all; don't let it put you off. We all make mistakes. Visiting from DISCO3.CO.UK
Wed Mar 18 2015 4:59pm |
S22SRH Member Since: 17 Mar 2015 Location: Maidstone Kent Posts: 6 |
Many thanks guys, is their a preference over the two???? |
Wed Mar 18 2015 5:27pm |
I'll leave that for others to answer but if you search this forum there are many opinions available. I love my TDV8 but they do seem to have the ability to explode and eat their turbo's at random even though I and many others have not had a problem. A decent warranty protects you from this.
Wed Mar 18 2015 5:31pm |
Great advice thank you, any other points of importance to look at?? Air suspension for one? |
Wed Mar 18 2015 5:50pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8863 |
All you can do is check everything works appropriately but be aware that things tend to go wrong out of the blue. Suspension should raise and lower a couple of times before it slows down. If not, suspect a tired compressor. If you can see a full pack of receipts for work done etc. then that'll be helpful. A load of stamps in the service book alone won't tell you much to be honest. Having said that, make sure that services have been done at 15k miles or 12 months whichever is sooner - you want at least one service a year. If they do more than 15k miles a year then there should be more frequent services in the records.
Wed Mar 18 2015 11:40pm |
I have found a SC RRS with 34000 miles on it and 6 LR stamps in the book. Are these belt driven and if so would it need doing on the year considering the low mileage??
Thu Mar 19 2015 3:14pm |
The S/C is chain drive for the camshafts. 2012 SDV6 - it's missing a couple of cylinders
Thu Mar 19 2015 7:54pm |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 |
I have moved from the Disco 3/4 site, the TDV6 is a soft engine with well documented oil pump failures at the belt tentioner, I have just done a overhaul on mine and the idlers and belt tensioners all are prone to high wear.
Thu Mar 19 2015 8:07pm |
ziglo Member Since: 20 Feb 2015 Location: channel islands Posts: 19 |
On the air suspension one other important test that should be done is to let the vehicle stand at normal ride height for 24 hours and check the suspension hasn't dramatically dropped, a slight drop maybe normal depending on how level the ground is but yea my RRS drops on the back side around 24 hours part of the vehicle is almost on the bump stops this isn't detectable unless you just leave it sit without starting and re pressuring the air suspension system.
Thu Mar 19 2015 10:26pm |
Thanks everyone for the advice, i will check all the things you have suggested.
Thu Mar 19 2015 10:31pm |
