Home > Maintenance & Modifications > Key Fob Spring?
zaphod
Key Fob Spring?
This is a trivial problem in the grand scheme of things but it does bug me Wink
Basically the spring in my fob doesn't have much 'spring' in it - when I press the fob button the key barely moves at all. Is there a way to replace the spring at all?
Post #450665 Sun Feb 01 2015 11:05am
zaphod
Thought a photo might make it clearer... the key should flip out 180 degrees when the button is pressed but it's just loose...
Post #450735 Sun Feb 01 2015 4:07pm
B9BS X
looks like your key could do with a new case which I believe comes with a new spring, only way to get to the spring is to pry the key open which you wont be able to put back together Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #450743 Sun Feb 01 2015 4:33pm
zaphod
Sounds like a plan - something like this?
http://www.ebay.co.uk/itm/Black-3-Button-R...418b58984f
Seems very cheap... Is it a fairly straightforward job to do?
Post #450752 Sun Feb 01 2015 4:48pm
B9BS X
yep thats the one, I think theres a video somewere on here or can check on youtube Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #450762 Sun Feb 01 2015 5:27pm
zaphod
As good as new now, for less than £6 Thumbs Up
Old one was a swine to open though, like you said, no chance of putting it back together afterwards. Think I will do my other fob now, looks much better in a fresh new case.
Post #451482 Thu Feb 05 2015 10:11pm
myfirstrrs
Good job Thumbs Up
Post #451483 Thu Feb 05 2015 10:13pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Did you have to glue it shut again? I'm not Fat. RRS TDV6 HST.
Post #451484 Thu Feb 05 2015 10:14pm
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
I did mine, yes they have to be glued shut. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #451485 Thu Feb 05 2015 10:17pm
zaphod
Yeah, just used some epoxy resin around the inside edge and clamped it overnight. Smile
Post #451488 Thu Feb 05 2015 10:19pm
Paddi
Nice job but be warned epoxy doesn't stick to the case very well and it will come apart. Super glue however works perfectly.
Thumbs Up 2008 MY Java Black TDV8 HSE
Post #451556 Fri Feb 06 2015 11:18am
zaphod
Big Cry
I tried polystyrene cement first but the plastic wasn't having any of that which is why I used the epoxy. Will see how it goes, if it all comes apart one day I'll give the superglue a try Thumbs Up
Just out of interest the owners manual says the battery is rechargeable and recharges when the key is in the ignition... However now I've seen how they are made I don't see how that is possible as there is no connection between the key blade and the circuit board/battery? Anyone know how it works?
Post #451559 Fri Feb 06 2015 11:33am
Paddi
Know the feeling - I tried all sorts of adhesives without success until I found a Land Rover TSB about repairing key fob cases that specified cyanocrylate (i.e. super glue) and that was completely successful.
The battery recharges by the principle of induction so no physical connection is required. Thumbs Up
The batteries don't last indefinitely (but can be changed now you know how to get the case apart) and not using the fob shortens the battery's life so it is a good idea to swop with your spare key every couple of weeks or so. 2008 MY Java Black TDV8 HSE
Post #451566 Fri Feb 06 2015 1:09pm
Lost for Words
It charges via hall effect. http://en.wikipedia.org/wiki/Hall_effect Thumbs Up Visiting from DISCO3.CO.UK
Post #451575 Fri Feb 06 2015 2:03pm
zaphod
Cheers guys, so basically it charges wirelessly like my phone. I'll try to make sure I use both fobs to keep them charged up Thumbs Up
Post #451583 Fri Feb 06 2015 3:12pm
