Home > General > Help looking for a replacement 2.7 TDV6 |
Nhlboy44 Member Since: 29 Nov 2014 Location: Essex Posts: 18 |
Hi Mikey Well here is another twist when my guy came over today the engine is turning over ??? He wasn't sure what to do now so is going to try speak to a friend who has worked on rr Any ideas ? |
Fri Jan 02 2015 11:44pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4347 |
Had the same with my own car. When the engine was hot, everything seized up. When it was cold, it would turn over fine, and given enough persuasion, it would run... |
Fri Jan 02 2015 11:47pm |
And what was the problem? |
Sat Jan 03 2015 8:26am |
Oil filter fitted wrong, causing the oil flow through the engine to be affected, and piston started overheating and melting... |
Sat Jan 03 2015 9:37am |
Ok
Sun Jan 04 2015 6:34pm |
hi Mikey
Sun Feb 01 2015 4:12pm |
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 |
Did you dismantle your engine to see what the fault was? |
Sun Feb 01 2015 6:41pm |
Not yet but my mechanic took sump off
Sun Feb 01 2015 9:41pm |
Sounds familiar...
Sun Feb 01 2015 10:08pm |
