Home > Detailing & Car Cleaning > Polishing Piano Black trim. |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Got the same problem with mine, nightmare to keep clean as well 2014 L405 SDV8 RR Autobiography
Fri Jan 23 2015 1:34am |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 |
T cut will remove the fine scratches, with a bit of elbow grease. MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's |
Fri Jan 23 2015 8:38am |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
Thanks. I'll give that a try and use some of the black hole and report back. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Fri Jan 23 2015 11:34am |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
I would definitely use a good but gentle polish but T cut is too abrasive in my opinion
Fri Jan 23 2015 10:39pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Any good car polish will remove surface blemishes and fine scratches as its only the top coat (lacquer) which is scratched. As said above good elbow rub and you'll be fine. |
Sat Jan 24 2015 9:14am |
The more abrasive the polish the more lacquer it removes… depends on the severity of the swirls …
Sat Jan 24 2015 10:06am |
Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104 |
I would consider putting a glaze and coat of wax on first in case you could get away with that, as glaze has no cutting ability be safer on the panel. |
Sat Jan 24 2015 4:44pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
I would have thought most polishes would make it worse as they would introduce more fine scratches and you can't break the polish down sufficiently by hand to get a decent finish. I'd try and glaze or sealant first too. FF 4.4 V8 Soooo looking forward to this bad boy
Sat Jan 24 2015 5:13pm |
Superclean Member Since: 28 Sep 2012 Location: Berkshire Posts: 133 |
I tend to remove the piano blacks from the interior and correct them on the mini bigfoot. But black hole glaze will silicone filler the defects to a certain degree. Thus giving the appearance of a better surface finish.
Mon Jan 26 2015 3:39pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Do not put T-cut any where near them
Mon Jan 26 2015 4:23pm |
Thanks all, black hole arrived the other day so will give it a go. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Mon Jan 26 2015 9:53pm |
