Home > General > Side strips on doors |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
Hello Calder.
Wed Jan 21 2015 8:59pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Rubber or plastic strip? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Jan 21 2015 9:02pm |
Calder Member Since: 10 Jan 2015 Location: Derby Posts: 21 |
Sorry the one thin one half way down the door as per pic
Wed Jan 21 2015 9:03pm |
In my gallery |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4861 |
Hi
Wed Jan 21 2015 9:07pm |
So I can remove with some heat and polish off the glue? |
Wed Jan 21 2015 9:38pm |
Yes they are held on with double sided tape only. Warm with hot air gun/Mrs hair dryer and shouldn't leave much glue. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Jan 22 2015 11:17pm |
Many thanks for the info I will be removing them at the weekend
Thu Jan 22 2015 11:36pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
You could always have them colour coded. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Jan 23 2015 10:53am |
No I think they look better with out them so off they come tomoz |
Fri Jan 23 2015 6:38pm |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
make sure any panels haven't been painted up to the rubber moulding as it could end up disastrous silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Fri Jan 23 2015 7:31pm |
Good thinking I will check first
Fri Jan 23 2015 8:02pm |
