Home > Maintenance & Modifications > Cheap engine oil ? |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Land Rover recommend Castrol Edge A5 5W-30 so seems similar |
Wed Jan 14 2015 4:51pm |
Royrw Member Since: 12 Nov 2014 Location: Glasgow Posts: 46 |
Thanks ABSport not 100% sure as I checked the Castrol web site & it states
Wed Jan 14 2015 4:55pm |
Looks like you found a bargain as I went on Castrol website see link below
Wed Jan 14 2015 5:18pm |
yes that's the A1 I mentioned but the Asda one is A5 ?? and just wanting a heads up on is it ok to do a full oil change with this stuff ? Range Rover Sport 2009 Stormer edition. |
Wed Jan 14 2015 5:20pm |
Not sure what A1 and A5 are but someone will be along shortly. Personally I'd use it. |
I like your thinking Range Rover Sport 2009 Stormer edition. |
Wed Jan 14 2015 5:21pm |
I used Mobile 5w-30 that was in Halfords and in their guide. Done a full oil change and all is well. |
Wed Jan 14 2015 5:22pm |
You should look on the label for Ford Specification WSS-M2C913-C.
Wed Jan 14 2015 5:29pm |
was it A1 or A5 ? Range Rover Sport 2009 Stormer edition. |
Wed Jan 14 2015 5:31pm |
That's what I used Paddi just got a genuine oil filter and replaced oil with Mobile 5w-30 from Halfrauds easy job |
I don't think it matters |
Wed Jan 14 2015 5:33pm |
Mobil Super 3000x1 Formula FE 5W-30 also conforms to ACEA A5/B5.
Wed Jan 14 2015 5:37pm |
Wed Jan 14 2015 5:46pm |
Cheers Range Rover Sport 2009 Stormer edition. |
Wed Jan 14 2015 5:51pm |
