Home > Technical > Juddering at 70mph |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Just the front wheels or the whole car? |
Sun Dec 28 2014 12:51am |
Chado Member Since: 09 Apr 2014 Location: Sheffield Posts: 10 |
The whole car judders, it was the front wheels I've had balanced. |
Sun Dec 28 2014 12:55am |
Try having all the wheels balanced. This can be very tricky to solve. My 2008 had:
Sun Dec 28 2014 3:21pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
You don't,say what mileage is on your sport, but as you have already tried, wheel balance or even 4 wheel alignment is the first route to go down. After that, if you have a higher mileage car the torque converter could be the problem. I believe it,s referred to as the cattle grid effect, because it's just like driving across one.
Tue Dec 30 2014 6:50am |
Jay2012 Member Since: 01 Jul 2012 Location: Uk Posts: 21 |
Do look at the vibration posts, but.. Sometimes the simplest things work.. I had same issues, LR replaced half shafts; and considered propshaft.. However, it turned out to be wheel balance! They were balanced by a specialist and the vibration went. The dealer found this by trying a different set of wheels before ordering all the prop parts suggested by LR.. Good on them. So, if possible try that too |
Mon Jan 05 2015 9:36pm |
Minshy Member Since: 06 Jun 2014 Location: Mottram Posts: 48 |
I had same issue. It turned out to be water in one of the back wheels. Tyre guy said never ever seen that before.
Mon Jan 05 2015 10:02pm |
It was water in both back tyres! Not sure how it got in there - anyone know? |
Fri Mar 20 2015 11:21pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Water could get into your wheels from the airline if the garage you use hasn't drained there compressor and don't have a water trap. 2008 G4 RRSport TDV8 current
Sat Mar 21 2015 7:40am |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
.....warped brake discs maybe? I was born with a photographic memory. Shame it didn't develop!
Sat Mar 21 2015 9:35am |
Camelrock
Sun Mar 22 2015 5:12pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Could the water be from a pressure washer? You'd have to hold it close to the tyre bead for a while, admittedly. I'm in the shed, I'll be back in the real world in a minute. |
Sun Mar 22 2015 5:28pm |
Hi chaps,
Wed Mar 25 2015 7:44pm |
Htailor23 Member Since: 01 Jan 2014 Location: London Posts: 7 |
Thu May 14 2015 2:39pm |
Papa kilo Member Since: 17 May 2015 Location: Preston Posts: 3 |
Sun May 17 2015 10:30pm |
