Home > Maintenance & Modifications > Ready for the cold |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Now why didn't LR do that. Instead I have to have a separate remote which bangs on dash when key in ignition 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Dec 22 2014 9:32am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
I've got one of the controllers with the wire to allow the use of the L/R button but have only installed it to use the plip remote. Where do you run the additional wire to? I spoke to Pete and he mentioned something to do with the lights but as I was expecting to use the plip remote I didn't get any details from him at the time.
Mon Dec 22 2014 11:12am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Run it down to the headlight and connect to the wire that goes to pin 11 on the headlight connector its the same colour as the wire from the controller blue/pink I think. Then programme the remote to operate the headlight curtesy delay 2008 G4 RRSport TDV8 current
Mon Dec 22 2014 11:19am |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
where do you fix the controller box and where do you connect the battery wire ?
Tue Dec 30 2014 6:47pm |
My controller box just sits in the battery box between the battery and the box wall. The positive wire connects to the battery wire that connects to the megafuse. The earth is just on one of the body earth studs next to the heater.
Tue Dec 30 2014 10:33pm |
did you all use a 1volt inline fuse to fit this ? |
Wed Dec 31 2014 2:13pm |
Yes fitted an inline fuse with 1amp fuse, you have to use a glass fuse and holder as the spade fuses only go down to 2amp. 2008 G4 RRSport TDV8 current
Wed Dec 31 2014 3:51pm |
just been informed that you don't realy need a fuse as the box is so close to the battery |
Wed Dec 31 2014 5:38pm |
J.blase Member Since: 01 Jan 2014 Location: Essex Posts: 24 |
Just fitted mine took 1/2 hour very straight forward. What temp dose it have to go down to before it works thanks john. Ps thanks bas autos. |
Wed Dec 31 2014 5:58pm |
you need a fuse, it's an electrical circuit, it makes no difference where the component is located.. 2008 G4 RRSport TDV8 current
Wed Dec 31 2014 6:05pm |
Hmm, I just followed the instructions that came with it. No mention of fuses being required, what rating, where they should go or how. Just a pair of ring connectors for the +ve and earth connections. 2012 SDV6 - it's missing a couple of cylinders
Wed Dec 31 2014 10:06pm |
If you go onto Bellauto's web site you find the fitting instructions there including the info about the fuse.. 2008 G4 RRSport TDV8 current
Thu Jan 01 2015 12:19am |
Must have missed that . Seems a bit odd not supplying a fuse / fuse holder in the wiring if it's required.
Thu Jan 01 2015 12:29am |
I thought the same it just says fit 1amp fuse (not supplied).. 2008 G4 RRSport TDV8 current
Thu Jan 01 2015 12:33am |
