Home > Technical > Air bag warning light advice !! |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi to all, my wonderfull air bag warning light keeps illuminating every other journey on the dash, any ideas would be appreciated on this one, thanks in advance 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Dec 21 2014 2:08pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
2 main causes
Sun Dec 21 2014 3:05pm |
2 main causes
Sun Dec 21 2014 3:06pm |
Thanks for the replies, is it easy to pop the air bag out or am I asking myself too much, also where would I find the clock spring ? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Dec 21 2014 3:53pm |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
As above, is it an easy job? are we able to access the connection by raising it to highest position or do we have to unbolt the seat altogether? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Sun Dec 21 2014 4:00pm |
Forgot to mention or ask, will this affect the safety or the running of my RRS, cheers 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Dec 21 2014 6:11pm |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 |
Think there is a video on you tube on how to remove airbag, had to replace my clockspring recently to stop airbag light coming on, was easy enough to do make sure you check all connections as disco mikey says before replacing clockspring |
Sun Dec 21 2014 9:15pm |
Hi, and thanks for that, is the clock spring fitted in to the air bag unit ? I am wondering if I will see the clock spring if I order the tool for removing the unit. one more question is which seat are these plugs under ? cheers 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Dec 22 2014 9:56am |
The airbag is really simple to remove, you don't need to spend £20 on the powerful UK tool, just one of those wire coathangers that the dry cleaners favour would be fine.
Mon Dec 22 2014 10:32am |
Hi Bodsy, still at work unfortunately mate so won't be able to make it today, i'll check the plugs out under the seat but if no joy I will take you up on your offer, looks like its going to be the clock spring anyway, thanks again 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Dec 22 2014 1:29pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Wed Sep 21 2016 8:30pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 395 |
HI Guys I have a 2006 RRS SC and all has been fine until the battery died so had a new one fitted and now when I start the system check give one bing and the Airbag light is on.
Tue Jul 23 2019 11:25am |
Can anyone help? |
Fri Jul 26 2019 8:20am |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
which diagnostic did u use?
Fri Jul 26 2019 2:46pm |
